Modding Six Monitors!?
Discussion in 'Modding' started by XxSomberAngelxX, 12 May 2006.
  1. XxSomberAngelxX
    XxSomberAngelxX What's a Dremel?
    9 Apr 2006
    I was going home from work the other day an saw 6 moniters sitting in the garbage, I thought i might be able to use them for something why not pick them up? Into the car and home to find out that all 6 are in perfect workng order. Does anyone have any ideas on what I should do with them?
  2. Techno-Dann
    Techno-Dann Disgruntled kumquat
    22 Jan 2005
    Programming/development? 2 monitors really isn't enough for heavy-duty coding.
  3. AJB2K3
    AJB2K3 What's a Dremel?
    12 Dec 2005
    Or web design.
    Buy a duel output video card a two matrox triple head adapters and build a video wall.
  4. Oxnard
    Oxnard What's a Dremel?
    6 May 2006
    I shouldn't have thrown them out :[
    flight simulator?
  5. harvy
    harvy Minimodder
    12 Apr 2006
    any ideas as to how to get this set up? i couldnt get flight sim2004 to work with 2 monitors using my pny fx5200 (old but does the job ~ kinda) let alone the 12 or 13 being used in that setup!
    And as to what to do with them - use one with a video of a fire and chuck it in a fire place. Setup a dual or tripple display system for yourself and sell the ones left
  6. AJB2K3
    12 Dec 2005
    Buy a load of adapters from matrox and chain them to gether.
  7. Glider
    Glider /dev/null
    2 Aug 2005
    Note the huge pile of node pc's under the desk ;) More then one is powering all that monitor violence ;)
  8. harvy
    harvy Minimodder
    12 Apr 2006
    yea but im assuming he/she dnt have 12/13 pcs to run the lot? must be like 1 pc to 2 monitors or somethin, but i cant get even 2 views to come up in flight sim!
  9. Oxnard
    6 May 2006
    I'm positive you can run many monitors off one pc, check into what AJB2K3
    said.
  10. XxSomberAngelxX
    9 Apr 2006
    Ya ive only got one computer to run them off unfortunatly i like the idea of chaining those splitters hmmm, give me a few ideas.
  11. AJB2K3
    12 Dec 2005
  12. GiGo
    GiGo was once a nerd.....
    12 May 2002
    You can spend a bit of cash getting the matrox chain together, otherwise try ebay for some cheap dual heading GFX cards.
    I got myself a cheap 4mb 3dfx dual header (childish moment, hehehe, so funny) and it works fine.
    My system i've got four, my 19" LCD and my 19" CRT, a small lilliput and my TV. I've got them on 3 GFX cards. If I got another PCI-E card I could have 4 monitors and then use a 2 headed GFX card for another 2 monitors.
    Total I could infact have 10 monitors on my system if I max out my PCI slots, um.... the thought of that :D
    Regards
    GiGo
    PS Conclusion, I would just get a cheap dual headed card of ebay and hook up the 2 monitors and that way you've got 3 on there which TBH is more thsn enough for the normal person (FYI im not normal :p)
  13. bender386
    bender386 What's a Dremel?
    5 Jan 2006
  14. Hackjedi
    Hackjedi What's a Dremel?
    7 May 2004
    just g3t an asrock 939dual-sata2. The uli 1695 has tripple grapics interface. You can run three graphic cards at the same time (pci,agp,pci-e).
  15. jet123
    jet123 What's a Dremel?
    17 Apr 2006
    get a vga splitter box thing, that splits to 5 or so (one at my place does anyway)
  16. twistednet
    twistednet What's a Dremel?
    9 Dec 2005
    i want a setup like that :D
  17. cobalt6700
    cobalt6700 Minimodder
    17 Oct 2005
    there aweome boardsa arnt they!
    ive got one at the moment, and ive seen one it a PCI-e, AGP, and two dual head PCI cards.
    8 screens.
    sorted
  18. scq
    scq What's a Dremel?
    4 Mar 2005
    Maybe just set them up in a circle, with the screens facing each other, and turn them on to irradiate any food you may want to preserve, or reconstitute spoiled food into edible stuffs again!
  19. ridiculous
    ridiculous What's a Dremel?
    21 Jan 2005
    all i know is if you put 6 crt monitors in the same room you are going to cook
  20. Kobalt
    Kobalt What's a Dremel?
    26 Aug 2003
