SketchUp Sketchup Components Collection (SCC) Discussion
Discussion in 'Modding' started by jezmck, 25 Nov 2003.
  1. rool
    rool What's a Dremel?
    29 Aug 2003
    I must say thanks, these models are great. Made many drawings using them.
    I'm missing a model of an Epia board though. Has anoyne made one?
  2. Pug
    Pug What's a Heatsink?
    16 May 2002
    Awesome contribution Jazzle. :rock: :thumb:
    I'd been put off using Sketchup till now but I reckon you just smoothed out a massive chunk of the learning curve needed with this thread.
    Props man. :hip:
  3. jezmck
    jezmck Minimodder
    25 Sep 2003
    Thanks, but I also have to thank everyone who contributed models/advice/tutorials to the thread - it wouldn't be worth it without their contribution.
    And I should also thank *sniff* my girlfriend for putting up with me, and...
  4. hypocrisy86
    hypocrisy86 Banned
    27 Jan 2004
    those links still wont work.....
  5. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    Stupid Host... give me a few days to get another.
  6. Frink
    Frink What's a Dremel?
    13 Feb 2004
    :Edit: Fixed my issue. And thanks for the components in this thread, very handy.
  7. hypocrisy86
    hypocrisy86 Banned
    27 Jan 2004
  8. mcbeckel
    mcbeckel What's a Dremel?
    31 Aug 2003
    Coolermaster Musketeer...If anyone has any great pics of the needles and markings inside the windows, I can add that.
    SketchUp File
  9. jezmck
    jezmck Minimodder
    25 Sep 2003
    please don't add any dials - these models should just be sketches - as it is your model is perfect :thumb:
  10. Tulatin
    16 Oct 2003
    it should be noted that the drive is about .6 inches too wide, as is the cd-rom it's modelled on. Sorry to kill your party chap.
  11. ouija
    ouija Trust me, I am doctor!
    10 Nov 2002
    The width of the model is 100% accurate.
    CD-ROM bays are not 5 1/4" wide
  12. Tulatin
    16 Oct 2003
    in-bloody deed.... it would have been nice if they called them 5 3/4 inch bays....
  13. ouija
    10 Nov 2002
    5 1/4" floppy discs were 5 1/4" wide
  14. Tulatin
    16 Oct 2003
    well that would explain it... well, this just goes and buggers my case designs....
  15. ouija
    10 Nov 2002
    If the design is to scale, you can resize the entire model to a specific dimension and replace the incorrect line with one that is 5 13/16" wide
  16. Tulatin
    16 Oct 2003
    Not that Easy Ouija. These cases have inch thick cut bezels, and drive cages. Btw - what's the accurate dimensions on 3 1/2 drives?
  17. ouija
    10 Nov 2002
  18. Tulatin
    16 Oct 2003
    Ah bugger. There goes the case. 5.75*1.5, 4*1
  19. philb
    philb What's a Dremel?
    2 Jan 2004
    very noob question on sketchup
    just downloaded it but thetutorilas are ****.
    get how most of it works nut how do you round edges like on the edge of if it not a straight 90 degrre join? Chamfered like the edge of table?
    and are all your drwaings to scale?
    last one how do you make thing protrude at a certain angle?
  20. ouija
    10 Nov 2002
    The video tutorials are superb for beginners.
    Use the measure tool and draw an arc on the corner you want to round.
    There is also a protrator tool.
    All my models are to scale, can't say the same for everyone though.
