SketchUp Sketchup Components Collection (SCC) Discussion
Discussion in 'Modding' started by jezmck, 25 Nov 2003.
  1. tominated
    tominated What's a Dremel?
    28 May 2008
    Omgwtfbbq! Awesome!!!!
  2. Aterius Gmork
    Aterius Gmork smell the ashes
    25 Sep 2007
    Does Kerkythea work with it? Is it any better than Version 6? Didn't get time to try but some things sound intriguing. :naughty:
  3. bentleya
    bentleya Lian Li Snail :)
    2 Feb 2008
    yerp it is worth getting and yerp it does work with Kerkythea
  4. Nexxo
    23 Oct 2001
    Definitely worth it. SketchUp 7 has really been cleaned up. It works faster in Vista (thank God), the snap points are more easily evoked, and lines now intersect and snap to surfaces properly. Moreover, guide points and lines in the context of an object are now also properly acknowledged when drawing outside the context of that object.
    It makes for a lot easier and intuitive working. I knocked out the design for Ada in about an hour.
  5. tranc3
    tranc3 ADHD Modder
    16 Jul 2007
    Wow i didn't know 7 was out, I've been working with the old stuff. installing it tonight. I may be uploading some models to mother board, heat sink, ram kinda things.
  6. jezmck
    jezmck Minimodder
    25 Sep 2003
    sounds good :)
  7. ricickle
    ricickle Reamer
    27 Mar 2008
    Anyone know where i can get a sketchup model of the Coolermaster cosmos s I've searched this thread and Google and found nothing.
  8. Aterius Gmork
    25 Sep 2007
    Not at all. Gotta do one yourself. :p
    I'd also be willing to help you out if you are kind enough to send me one. ;)
  9. ricickle
    ricickle Reamer
    27 Mar 2008
    Ill give it a go maybe
    only ever used sketchup to place components in case etc to plan for mods.
  10. jezmck
    jezmck Minimodder
    25 Sep 2003
    take the next step!
  11. Asulc
    Asulc Minimodder
    18 Jul 2007
    Ok, so I am going to be modding a Silverstone ft01 this coming year if all goes well. However, I would like to do my planning in Sketchup. I am having trouble converting the TJ-07 to an FT01... I dunno if this is a good way to start my model, but it seems easier to me. One problem that I am having is getting the interior redesigned. Any help anyone could give me would be awesome! Better yet, if one of you sketchup gurus could design it for me yourself, I would be forever in your debt!
  12. jezmck
    jezmck Minimodder
    25 Sep 2003
    I've been informed that the Key Switch by Ravimade is no longer available, has anybody got the file?
    I'd like to re-add it if possible, rather than have to delete it from the collection.
  13. Asulc
    Asulc Minimodder
    18 Jul 2007
    I have been working more on converting the TJ-07 to an FT01. But I am stuck.
    I cant seem to find an easy way to get the width right. I don't know how to upload my sketchup file, but if someone could help me with that or tell me how to do it, that would be great.
    Edit: Here is a picture of where I currently am.
    The dimensions of the case are still that of the TJ-07.
  14. tominated
    28 May 2008
    a cool thing with sketchup to help with that is if you look side on to the case, you can just select the lines and use the move tool - it'll move not just the lines, but the faces also. If you want, i'll give is a bash.
  15. scooby
    scooby Minimodder
    3 Mar 2004
    @Asulc, whats the width?
    I did the TJ-07 in grouped sections, so it shouldn't be that hard to covert. Just do it a section at a time.
    Scooby:thumb:
  16. Asulc
    Asulc Minimodder
    18 Jul 2007
    @tominated, I would appreciate any help! Thank you for the offer!
    @scooby, 211mm (w), 486mm (h), 494.5 (d)
    I know that you can use the move tool and it should work fairly well. However, on the edges of the case where the ridge is, I can't seem to be able to move all of that in...
  17. FrooP
    FrooP can I eat this?
    24 Oct 2007
    do want model?
  18. jezmck
    jezmck Minimodder
    25 Sep 2003
    ya bitte!
    Looks great.
  19. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    7's great. I've gone back to block designing with it...
  20. FrooP
    24 Oct 2007
