SketchUp Sketchup Components Collection (SCC) Discussion
Discussion in 'Modding' started by jezmck, 25 Nov 2003.
  1. Dark~3nergy
    Dark~3nergy what was dat sandvich ?
    14 Jan 2007
    no need to rush :)
  2. jezmck
    jezmck Minimodder
    25 Sep 2003
  3. Vehement
    Vehement What's a Dremel?
    25 Jan 2010
    My model is FINALY complete!
    Silverstone TJ07, accurate to 1mm.
    Hope this helps everyone with their modding, please let me know if you create any good models from it.
    If you spot any errors or possible improvements, please contact me.
    Enjoy! :D
  4. Cuzza
    Cuzza What's a Dremel?
    14 Apr 2010
    Once again I am left feeing inadequate.
  5. Ron-ski
    Ron-ski What's a Dremel?
    13 Jul 2009
    Yeah, I spotted one, you didn't finish assembling it, only kidding, looks fantastic. Well done, excellent job, must have taken ages to draw, very impressive.
  6. jprykov
    jprykov What's a Dremel?
    29 Oct 2010
    Need coolermaster haf x case sketchup. ty :)
  7. Vehement
    25 Jan 2010
    Your socket models are awesome though, I started one and promptly gave up.
    Thanks Ron-ski.
    To be honest its a very easy case to draw, as there isnt many complicated shapes. It just took so long to measure, especially since the system was running at the time o.0
  8. Cuzza
    14 Apr 2010
    Measuring can be a pain. That's why I do mine from pictures and guesswork
  9. Ron-ski
    13 Jul 2009
    But measuring is the only way to be sure it's accurate, a digital vernier can be bought for around £20, sometimes less. I used one when I drew my Laing D5 Vario Pump (MCP655) + EK-D5 Top Rev 2.
  10. Vehement
    25 Jan 2010
    I started this model with a tape measure and ruler, then got a digital vernier. Ended up remodelling earlier parts more accurately, and in half the time.
    Its the best way to measure holes, tubes and thickneses also.
  11. Nexxo
    23 Oct 2001
    Totally agree. It is very important to make a model as dimensionally accurate as possible. People plan their designs around these components, after all. I resubmitted my most recent contribution because it was 2 mm out.
  12. Cuzza
    14 Apr 2010
    Hmmm. I take back what I said. The real reason I don't measure things is because I generally don't own the parts. That's the whole idea of the modeling, check to see if it will work before you buy the bits! I do try to use technical drawings when I can find them, and using a good photo you can make educated guesses to the other dimensions.
    Fore sure if I had the parts to measure, I would. I do own a nice (non-digital) vernier caliper.
    There are always a lot of details in parts which ultimately are only aesthetic and won't affect the placement of the part. If you get the overall dimensions right it won't cause too many problems.
    I suppose I should put up a disclaimer: I make no guarantees about the accuracy of my sketchup models.
  13. Nexxo
    23 Oct 2001
    That's OK; I often have to rely on technical drawings as well. My rule of thumb is that if I do not have access to the part or schematic drawings of it I do not model it because it just ends up being guesswork. Usually it is only the main dimensions that really matter though. Still a disclaimer is good.
  14. Vehement
    25 Jan 2010
    Bit of a boring model, but I thought it may be usefull.
    Blank motherboard backplate submitted to SCC
  15. Blackbriar
    Blackbriar What's a Dremel?
    5 Nov 2010
    I search a modell of a HAF X
    But i don´t find anything on web.
    can anyone help me?
  16. k0rben
    k0rben I use my dremel as a toothbrush
    22 Jul 2010
    I suggest using any sketchup version but saving in SKETCHUP 7.skp to ensure back compatibility.
    the saves from 8 and saves from 7 have no diferencies imho.
    (e.g the blank backplate i wanted is in 8 :worried:)
  17. Ron-ski
    13 Jul 2009
    Why not just install Sketchup 8?
    If you have to use 7 then you can install 8 as well, they will co-exist quite happily as far as I'm aware, then use 8 to save a version 7 file.
  18. asura
    asura jack of all trades
    22 Apr 2009
    Yup ron-ski they work perfectly happily side by side, I'm using SU6,7&8 !
    6 for dfx importing
    7 for working in as it's the version that my 3D mouse works with
    8 for bullion and saving for archiving
  19. Blackbriar
    5 Nov 2010
    I need a model of the HAF X , please help me =)
  20. jezmck
    jezmck Minimodder
    25 Sep 2003
    Hi all,
    just wanted to report that I've had my first ever hosting donation!
    Thanks to Pavel.
    Also to ask if anyone else can help with the remaining missing remotely hosted files, as listed at http://scc.jezmckean.com/remote , thanks in advance.
