SketchUp Sketchup Components Collection (SCC) Discussion
Discussion in 'Modding' started by jezmck, 25 Nov 2003.
  1. lenne0815
    lenne0815 What has been seen cannot be unseen
    4 Jul 2009
    I had it happenig a cpouple of times aswell, i think its because sketchup shifts its focal point by itself all the time, the problem occurs if u zoom in to a part and the focal point lays way behind it, it happens in the other direction aswell su the cuts off the rear end of a model, im not sure if there a button to reset the focal point ?
  2. jezmck
    jezmck Minimodder
    25 Sep 2003
    Just added the latest 4 submissions, including the 500th item!
    http://scc.jezmckean.com/latest
    Thanks to all the authors, without you the site wouldn't make me 11p a day!
    Razer2007 likes this.
  3. Cuzza
    Cuzza What's a Dremel?
    14 Apr 2010
    *whistle* wow 500 items! I say thanks to all the other great sketchuppers who keep pushing the boundaries, forcing me to make my models better
  4. danitgeek
    danitgeek Designer
    17 Sep 2010
    Does anyone have a gtx 580 model?
  5. asura
    asura jack of all trades
    22 Apr 2009
    If you're willing to supply the card, I'm willing to put in the hard, hard work or making the model :p
  6. Cuzza
    14 Apr 2010
    Maybe we should petition manufacturers to provide us with on-loan "review samples" to model in sketchup.
  7. asura
    22 Apr 2009
    Or maybe someone should petition Bit-Tech for a job modelling up their review samples?
    ...Or they could just give us their design specs, after all these things are designed before their built... It wouldn't be too much haste to take a dimensioned pdf and through together an accurate SketchUp model.
  8. Razer2007
    Razer2007 Building Proxima
    18 Jul 2010
    I have a request, and maybe if something like it exists, please give a download link.
    I am looking for a fairly detailed Apple Power-mac G5 case.
  9. asura
    22 Apr 2009
    This guy has had the briefest of goes at the internals, but hasn't even indicated the panel thickness, so beyond that... nope, sorry.
  10. Razer2007
    18 Jul 2010
    hahha I dl'd it, and um... yeah. the one I got is better sorry. But thank you for the help.
    +rep.
  11. Hawaii
    Hawaii passerby
    10 Aug 2008
    Speaking of better models :), I'd like to point out that the head of a low profile bracket is quite different from that you find on high profile. You can fix your HD5750 LP by the official design specs: PCI Express Card Electromechanical Specification Revision 1.0a (page 74 and 75).
  12. Cuzza
    14 Apr 2010
    OK Hawaii, thanks for the input. Will do when I find some time, and especially thanks for the Spec Sheet, can never seem to find that stuff when I need it. Will save for later.
    Purely by coincidence I have just finished off another pci-e related model, the motherboard connector slot:
    http://www.mediafire.com/?9x89b7z8exw3xwr
    I did measure the dimensions properly or took some of them from a (different) spec sheet, so most should be close to perfect. I really can't be bothered putting in the electrical pins in the slot, so I won't. Otherwise feel free to be critical.
  13. asura
    22 Apr 2009
    Critical... critical... um... You tend to use fragments in your sentence structure? :D
    Very tight model, most impressive! :thumb:
  14. Cuzza
    14 Apr 2010
    OK I have submitted it, also included a x1 slot in the same file.
  15. craigr1982
    craigr1982 What's a Dremel?
    29 Jun 2006
    Just jumped on google to jazzle and although the website is correct google's search result shows viagra as the site name and underneath
    This site may be compromised.
    Site still works fine as far as I can tell, but figured I post here in case jez didnt know.
  16. Ron-ski
    Ron-ski What's a Dremel?
    13 Jul 2009
    I'm seeing the following when I google sketchup components, no mention of Viagra, but still a worrying result.
  17. jezmck
    jezmck Minimodder
    25 Sep 2003
    Yeah, my hosting got hacked a little while ago, all cleaned now, and resubmitted to Google.
  18. Cuzza
    14 Apr 2010
    DONE:
    jez if you could update on the SCC that would be cool, new thumb here
    http://i.imgur.com/Nk3B1.png
    new file here
    http://www.mediafire.com/?1we6ishbs9of8d6
  19. jezmck
    jezmck Minimodder
    25 Sep 2003
    Done.
    And I've added Cuzza's PCI-e slot model too: http://scc.jezmckean.com/item/502
    Amazed we didn't already have one!
  20. danitgeek
    danitgeek Designer
    17 Sep 2010
    Thanks To RaMansell
