SketchUp Sketchup Components Collection (SCC) Discussion
Discussion in 'Modding' started by jezmck, 25 Nov 2003.
  1. Dark~3nergy
    Dark~3nergy what was dat sandvich ?
    14 Jan 2007
  2. jezmck
    jezmck Minimodder
    25 Sep 2003
  3. Dark~3nergy
    14 Jan 2007
    Thx :)
    It was made in 3ds max and rendered with vray 2.0
    If anyone is interested I can upload the max file or an obj file.
  4. Razer2007
    Razer2007 Building Proxima
    18 Jul 2010
    Dark~3, What is the size of 3ds max?
  5. jezmck
    jezmck Minimodder
    25 Sep 2003
    How did you convert from 3ds to skp?
  6. GuilleAcoustic
    GuilleAcoustic Ook ? Ook !
    26 Nov 2010
    Size is generaly really smaller than with SU. Low poly + meshsmooth helps a lot :thumb:
  7. Dark~3nergy
    14 Jan 2007
    I exported to .3ds and imported it in SU And modified it slightly to reduce to polycount a bit.
    Razer, I'm not at home ATM but I'll tell you when I get home, but I don't think it's very large.
  8. jrs77
    jrs77 Modder
    17 Feb 2006
    How is V-Ray 2.0? Is it any faster then 1.5? And maybe you can tell how V-Ray RT works with the GPU?
  9. jezmck
    jezmck Minimodder
    25 Sep 2003
    *ahem* than *ahem*
  10. Dark~3nergy
    14 Jan 2007
    Its quite faster then 1.5, but not extremely. And for vray rt, I never use it, there are alot of unsupported features and it the quality is inferior than the normal vray. But for simple scenes it works well, when you don't use complex materials.
  11. Sk8rSeth
    Sk8rSeth Browncoat
    6 Aug 2011
    can someone please make a model of the ASUS Matrix GTX 580?
    photos can be found here;
    ASUS Matrix; The Card
    i really need one of these modeled and i dont know how to do it myself. please and thanks!!!
  12. ianclowe4c
    ianclowe4c What's a Dremel?
    17 Jul 2004
    Does anyone have or know where the Lian Li V354B or the MSI Z68 or MSI Z68MA-ED55 B3.
  13. Dark~3nergy
    14 Jan 2007
    i think there's a wrong link or wrong file for an item on the site, the "Koolance CPU-360" by subtec.
    when i opened it i got the "Koolance CHC-122".
    just thought i should point it out :)
  14. jezmck
    jezmck Minimodder
    25 Sep 2003
    Thanks.
    I've found the original submissions and it appears that subtec sent the same link for the skp.
    I've emailed a request for the correct file.
  15. jezmck
    jezmck Minimodder
    25 Sep 2003
    subtec has given me the correct file and has updated a few others, many thanks to him :D
  16. alain-s
    alain-s Minimodder
    12 Jan 2011
    Thx To share this Mick
    I hope u don't mind that i use some models from u
    Thx to Razer i started to make a model in SU to when i saw his new project.
  17. bigkingfun
    bigkingfun Tinkering addict
    27 Jul 2008
    It seems the files are not compatible with Solidworks.
    Is there any way to convert them?
  18. SnowyOwl
    SnowyOwl What's a Dremel?
    6 Jul 2010
    Get sketchup PRO .....export Sketch up file as DWG..... then import into Solidworks.
    It works but it creates a million triangle so be aware these files require a LOT of computing power.
  19. asura
    asura jack of all trades
    22 Apr 2009
    Or work in SU6 when .skp-.dfx was included in the free package. Or try and find someone with the plugin which does the same thing (googe released it for about a month, a month after everyone went ape that file transfer support had been nerffed)
  20. jrs77
    jrs77 Modder
    17 Feb 2006
    I've made a 100% exact model of the ATX, µATX and mini iTX specification including the according cutouts needed for the motherboardtray.
    All the parts in the model are arranged and aligned properly to be a startingpoint for modeling a scratchbuild.
    No thickness is added to the motherboardtray and the holes are just drawn onto the surface but not cutout so you can start a scratchbuild by just adding thickness of your chosen material, removing unneeded holes etc, etc...
    It's a tiny file of 733kb and zipped only 124kb -> http://sharesend.com/vnn25
    The measurements were taken from reliable sources and are 100% exact that way. For the general ATX specifications I used http://www.formfactors.org/developer\specs\atx2_2.pdf which is known for a while, but unfortunately doesn't come with the PCI-cutouts. So in addition I worked with this source -> http://www.protocase.com/pdf/How_to_design_enclosures_for_motherboard_based_systems_092010.pdf.
    Dark~3nergy likes this.
