SketchUp Sketchup Components Collection (SCC) Discussion
Discussion in 'Modding' started by jezmck, 25 Nov 2003.
  1. ferret141
    ferret141 Minimodder
    18 Oct 2010
    Are the internals accurate?
    Teelzebub likes this.
  2. Maki role
    Maki role Dale you're on a roll... Lover of bit-tech
    9 Jan 2012
    If by internals you mean have I modeled all the interior pipes and reservoir bits, no. I didn't think that people would be using this for complex computational fluid dynamics so I didn't think it would be worth the time... :p
    However, the ports are in exactly the right place, which combined with accurate outside are about as far as any normal user would require.
    These are the models I'm using to scale my next project so they'd better fit properly :worried:
    Anywho, I finished an XSPC Raystorm CPU block also:
    Download link: Here
    Again this is a rather high poly model (given it's size) so bear that in mind if you'd like to use it. I've modeled some of the interior parts as it's visible through the acrylic. I didn't bother with the inside of the block itself though, given it won't ever be seen so would be just a waste of resources.
  3. Maki role
    9 Jan 2012
    So today I decided to have a stab at modeling an EK D5 X-Top complete with an Laing D5 Vario pump installed. It should all be accurate to the same degree as the models I posted above.
    The model doesn't come with the wires and plugs sadly as they won't really be usable after exporting (just static geometry).
    Download link: Here
  4. Maki role
    9 Jan 2012
    Okay Just finished a Corsair RM650 power supply:
    Download link: Here
  5. RooiDuiwel
    RooiDuiwel What's a Dremel?
    20 Sep 2009
    @Maki
    those are some epic models and WD to you on sharing them
    will definitely help out in going DIY case or just fitting parts in general
  6. ferret141
    18 Oct 2010
    I was contemplating running it through cfd :D
  7. jrs77
    jrs77 Modder
    17 Feb 2006
    Little something for you HTPC-builders.
    Thermalright AXP-200 including the TY-140 fan.
    Download here
    Submitted to SCC aswell and soon to be found there in the heatsinks & fans category.
  8. Falqoon
    Falqoon Minimodder
    13 May 2013
    Hi guys,
    I just started with sketchup to work out my new mod before starting it. I dont know everything yet obviously, but can anyone tell me why my sketchup gets stuck why i try to import the .stl files of maki role?
    I would have liked to use those components for testfitting and stuff.
    Please help me out!
    If this is not the correct thread, please point me onto the right direction :)
  9. jrs77
    jrs77 Modder
    17 Feb 2006
    The STL-files from Maki are not ment for SketchUp, but for AutoCad, Solidworks or any other big CAD-software.
    SketchUp isn't made for high poly models and gets stuck while trying to import them. With SketchUp you're looking for SKP-files.
  10. Falqoon
    Falqoon Minimodder
    13 May 2013
    Thanks for making clear! I thought it would just work, as there is an .STL import feature in SketchUp!
  11. jrs77
    jrs77 Modder
    17 Feb 2006
    You can import STL-files, but they need to consist of less polygons.
  12. Maki role
    9 Jan 2012
    Hey man, didn't realise that Sketchup had issues with the .stl files (they are decently high poly so I should have figured). I may be able export in some better formats for you tonight/tomorrow. Sketchup seems to import .dwg files quite well, so I'll see if I can make those. Any parts in particular that you were interested in?
  13. Falqoon
    Falqoon Minimodder
    13 May 2013
    Thanks man! That will help a lot.
    I'm interested in the radiator, pump, corsair psu and the dominator ram!
    If you could arrange so that i can get them in sketchup you're the man!!
  14. Nexxo
    Nexxo Rotate Your Owl For Science
    23 Oct 2001
    Have a look at Jazzle's SketchUp Collection (and then give the guy some well-deserved rep). Many of the components you are looking for are already there.
  15. ferret141
    18 Oct 2010
    Has anyone seen an RV02 model knocking about?
  16. jezmck
    jezmck Minimodder
    25 Sep 2003
    After over 10 years of running it, I'm going to be closing down my site.
    I will keep it online for the foreseeable future, but, unless there's huge demand, I will be removing the ability to submit new items.
    Let me know your thoughts. :)
    stonedsurd, Teelzebub and Nexxo like this.
  17. Nexxo
    23 Oct 2001
    I wonder if, since we have space for photo albums on Bit-Tech forums, we could also create a communal pool of just generally useful files: SketchUp components, templates, bits of code, diagrammes etc.
  18. GuilleAcoustic
    GuilleAcoustic Ook ? Ook !
    26 Nov 2010
    +1 to Nexxo's idea
  19. jrs77
    jrs77 Modder
    17 Feb 2006
    Bummer :(
  20. Meelobee
    Meelobee What's a Dremel?
    5 Nov 2003
    Aww :( Why are you closing it if you don't mind me asking? How much data in total and how much traffic a month does it generate? I would love to help out and could even host everything (depending on the traffic, but I'm sure it's not a problem)
    This! Is a great idea too :) Again, If needed I can/want to help :)
