SketchUp Sketchup Components Collection (SCC) Discussion
Discussion in 'Modding' started by jezmck, 25 Nov 2003.
  1. jezmck
    jezmck Minimodder
    25 Sep 2003
    i've been meaning to since i started the thread, but never got round to it.
    not yet looked at the model but it looks great - when i get a spare moment i will put on the front page.
    edit: done :)
  2. ouija
    ouija Trust me, I am doctor!
    10 Nov 2002
    Sorry, I didn't notice this reply. If you're still having problems, you should just be able to redraw over the bold lines and this should "heal" the square faces. That is why, in my tutorial, I rotate two sets of curves which already have the faces between them. This saves you from redrawing every single one, and when you copy the first set the faces are duplicated as well.
  3. DETN8R
    DETN8R What's a Dremel?
    27 Oct 2001
    Would it be possible for someone to get a model of the DFI Lanparty board?
  4. TechnoScream
    TechnoScream Minimodder
    12 Dec 2003
    this is great stuff, im glad to see this thread is still going, keep up the good work! :rock:
  5. ouija
    10 Nov 2002
    Expect to see a Coolermaster Wavemaster model in a short while ;)
  6. thecrownles
    thecrownles What's a Relix?
    27 Feb 2004
    edit: nevermind i found a place, sorry for the dead post :wallbash:
  7. red_rat
    red_rat What's a Dremel?
    11 Nov 2003
    this tread rocks :rock:
    can som body make a 120 mm fan?
    Sorry fore bad enlish im just an 13 year old swedish boy.
  8. CandyKing
    CandyKing What's a Dremel?
    24 Apr 2004
    This is my first sketchup object. (pc related anyway)
    I know the blades suck but I honestly gave up making more correct blades.. (and i didnt want to rip someones blades.. ) the measurements are correct though..
    in addition, I really like low-detailed objects.. if I need detail I use 3D Studio MAX...
    120mm.skp
    If someone want to put this in their DB, be my guest.. (its not that good)
    I could need a ATX motherboard.. with LOW details.. the one posted here really sucks my cpu/gpu dry..
    CandyKing
  9. ouija
    10 Nov 2002
    That's an excellent fan, especially to increase the speed of a model with the flat blades.
  10. CandyKing
    24 Apr 2004
    This is probably very unnecessary... Yet another 80mm fan.. (low detail)
    80mm.skp
    CandyKing
  11. jezmck
    jezmck Minimodder
    25 Sep 2003
    this is exactly the kind of thing i wanted - perfect amount of detail etc.
    Welcome to the forum, and thanks for the great input!
    (will put these on the front page).
    J
    to ouija - is that page any closer? give me a month and i'll have finished uni for ever and will do one then....
  12. CandyKing
    24 Apr 2004
    In the spirit of low level detail.. an ATX-478 mobo... and yes, you have seen it before.. its a low level detail remake of the Soyo SY-P4I875P DRAGON 2 (Platinum Edition) By El Nosba. (2419kb!) The only part which is a complete copy is the ram socket handle bars (white in pic)
    atx-478 (291kb)
    All credits and thanks to El Nosba.. I am in the starting phase of building a socket A mobo in the same leve of detail.. most probably the ASUS A7S333. (Since its what i got in my pc)
    CandyKing
    edit:
    i do NOT guarantee the sizes in the model. in seems to me that there are several discrepancies. If i get my hands on some 2d fact file on atx form factor standards i will update my file.. and let you know it..
  13. hyperdreamz
    hyperdreamz What's a Dremel?
    5 Apr 2004
    plz update front page link
    updated file with a few minor corrections
    ATX Motherboard + Motherboard Tray + Mounting Screws + Rear IO Panel
  14. jezmck
    jezmck Minimodder
    25 Sep 2003
    edit:
    links added and updated on front page.
  15. Buffi
    Buffi What's a Dremel?
    28 Apr 2004
    Are there any model for the epia mini-itx motherboards yet?
    That would be sweet
  16. CandyKing
    24 Apr 2004
    The atx-478 object is now updated! :rock:
    NOTE: the mounting holes are now correct according to the ATX 2.2 form factor (thanks hyperdreamz :thumb: ) the mother board is also modified to be a FULL SIZE atx mother board, so please forget all references to the Soyo SY-P4I875P DRAGON 2 mobo... this board is WIDER then the Soyo board..
    still, el nosba did a great jobb..
    CandyKing
  17. Rexxie
    Rexxie What's a Dremel?
    18 Nov 2002
    How is the updated PCI card model coming along?
  18. SJH
    SJH Minimodder
    24 Dec 2003
    This might be already in here, but at 20 pages I don't want to have to read the whole thread :p
    Anyway, has anybody got a rendering of the front panel of a Pioneer slot loading DVD drive?
    Not too bothered about the metal casing, just the front panel if possible.
    Thanks :D
    -Sam
  19. DETN8R
    27 Oct 2001
  20. boardsportsrule
    boardsportsrule What's a Dremel?
    9 May 2004
    are all the different components scattered thru thread, or just on front page?
