SketchUp Sketchup Components Collection (SCC) Discussion
Discussion in 'Modding' started by jezmck, 25 Nov 2003.
  1. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    if they steal them next time, just put in in big letters: This is what you get for pirating *******!
  2. <A88>
    <A88> Trust the Computer
    10 Jan 2004
    Could you pleeeaaase email me the file, as your hosting isn't working :(. Thankyou v much for making it, just what I needed :D
  3. CandyKing
    CandyKing What's a Dremel?
    24 Apr 2004
    I know, this object i problably of no use.. its a home made waterblock project from overklokking.no I just made the sketchupfile..
    vannblokk.skp
    i plan on updating it.. (adding some screws and so on.)
  4. Trekari
    Trekari What's a Dremel?
    10 Nov 2002
    FYI, From what I can see, pretty much everything in this thread that has a link has been hotlinked by aquapc.
    Mookie's stuff, ouija's, elnosba's etc. The whole works.
    Yea, I went and looked just before typing this.
  5. jezmck
    jezmck Minimodder
    25 Sep 2003
    :read:
    we know, see here, and here etc.
    I've gone to some extent to stop them getting the files, but don't have much control over the server.
  6. thinguy
    thinguy What's a Dremel?
    10 Apr 2002
    Would it be benefit to have all the sketchup files in one location?
    I'd be willing to host all of them at modchives.com.
  7. Mr.Nonflex
    Mr.Nonflex What's a Dremel?
    2 Jun 2004
    Hey, after looking throug this topic i have downloaded sketchup, thanks for the objects. Will try to use it to show the casemod i am going to make. :hip:
  8. jezmck
    jezmck Minimodder
    25 Sep 2003
    quite likely - how much control do you have over the server? If you want to start taking the files (with the author details etc) feel free. thanks!
  9. KAMIKAZE-FREAK
    KAMIKAZE-FREAK What's a Dremel?
    30 May 2004
    i red the whole thread
    but i didnt find a model for a Hydor L20 or L30 pump
    does anyone have this model? or is someone willing to make that model?
    many thanx
  10. Mr. Beta
    Mr. Beta What's a Dremel?
    27 Feb 2004
    Nice to see that this thread is still going. :thumb:
    Anybody know of another Sketchup Component Archive?
  11. robotguy9000
    robotguy9000 What's a Dremel?
    3 Jun 2004
    i sont have the time to read the whole thread but i do have a question-
    when you make somehting that is, for example, 16 inches long, it is TINY on the screen. how do you make it bigger without zooming in/ altering the dimensions of the line?
  12. Stickeh
    Stickeh Help me , Help you.
    20 Jul 2003
    scoll forwards on your mouse, this will take the view closer to the line.
  13. jezmck
    jezmck Minimodder
    25 Sep 2003
    that is zooming, but there isn't any other way to make it bigger (unless you want to change your resolution, but i don't think that's helpful)
  14. boardsportsrule
    boardsportsrule What's a Dremel?
    9 May 2004
    im workin on sketchup, but if some one wants to make a vantex 201, taht would be nice
    http://www.vantecusa.com/p_nxp_201.html
    lmk if u can :)
    EDIT: ok, lets say you have a square. and you want to put a circle inside that square..how do you make it so you work inside the square?(im trying to make a case :))
  15. jezmck
    jezmck Minimodder
    25 Sep 2003
    huh?
    are we talking 3D or 2D?
    do you want to draw a circle on the surface?
    show us a drawing of what you want to do...
  16. boardsportsrule
    9 May 2004
    never mind, i couldnt figure out how to insert a 2d rectangle into my 3d case, because i did the outside, and am now adding all the other random things needed,(ducts and stuff) but it just took a while..i must say, im quite impressed at how easy sketchup is to use...basic features of course :) thanks for all the great components in here...with out them i would be lost! :)
  17. KAMIKAZE-FREAK
    30 May 2004
  18. boardsportsrule
    9 May 2004
    hey, thanks! but your download doesnt work :/ that's all i need tho!
  19. jezmck
    jezmck Minimodder
    25 Sep 2003
    lack of detail is fine, but we really need components to be to accurate sizes - that just doesn't look right. can you make a new model with the actual measurements? if so replace the above pic and link. :)
  20. jezmck
    jezmck Minimodder
    25 Sep 2003
    lack of detail is fine, but we need models to be to scale.
