SketchUp Sketchup Components Collection (SCC) Discussion
Discussion in 'Modding' started by jezmck, 25 Nov 2003.
  1. robotguy9000
    robotguy9000 What's a Dremel?
    3 Jun 2004
    im in the proccess of making a good one, i have the actual thing. ;)
  2. robotguy9000
    3 Jun 2004
    mmk, im done. how do you host it? i have a paid web site...
    help!
    -confuzzled
  3. boardsportsrule
    boardsportsrule What's a Dremel?
    9 May 2004
    upload it to your website, then give us the link! :)
  4. [<x>] Kiyusoma
    [<x>] Kiyusoma Deus Ex Machina
    16 Jun 2004
    Anyone want to create a half height video card?
    Such as:
    PowerColor Radeon9600 SE
    Unfortunately i don't have anything such as sizes or height. about
    half the size of a normal agp. You might be able to tell form pic or linked gallery.
    Designing case in sketchup before buying componets......
    It's cheap under $80 USD :clap:
  5. KAMIKAZE-FREAK
    KAMIKAZE-FREAK What's a Dremel?
    30 May 2004
    my link now works by the way
    the link was to vantec_nexus.skp
    but the filename was Vantec_nexus.skp
    and i used the measurments named on the site
  6. SuperToadMan
    SuperToadMan What's a Dremel?
    27 May 2004
  7. KAMIKAZE-FREAK
    30 May 2004
  8. SuperToadMan
    27 May 2004
  9. KAMIKAZE-FREAK
    30 May 2004
  10. SuperToadMan
    27 May 2004
  11. Dodge
    Dodge What's a Dremel?
    10 Oct 2003
    how do you make a curved edge, i can make it in lines, but cant convert it to a 2d shape
    i want like a sheet of metal bent round 90 degreese
  12. jezmck
    jezmck Minimodder
    25 Sep 2003
    if edges are coplanar you will automatically get a surface. I don't really understand your problem.
    Do you want a 3D solid, or just a 2D sheet? Do you want the curve to be smooth or a right-angle?
  13. Nightingale_zero
    Nightingale_zero What's a Dremel?
    30 Dec 2003
    Anyone make an MSI K8T master 2 far? I doubt it but its worth a shot. I am just dabbling around in this program and have no were the skill to make components more a less just simple boxes etc.
  14. Stickeh
    Stickeh Help me , Help you.
    20 Jul 2003
    Hey Nightingale, the easiest thing to do to make a motherboard is make the simpilist of things, such sa placement of CPU socket, the PCI / AGP slots, ram slots etc.
    To do this easily, download one of the other mother boards and take off the components from it, and place it on yours! It'll save a lot of time and the outcome will be as of a high quality you wish for.
    SuperToadMan i have one of these over at a firends house, ill get him to model the basic box and ill do the rest adding the plug sockets etc.
  15. Dodge
    10 Oct 2003
    I wish to have a 2d sheet bended round a curve
    Code:
    something like that but rounder
  16. KAMIKAZE-FREAK
    30 May 2004
  17. jezmck
    jezmck Minimodder
    25 Sep 2003
    @Dodge:
    Okay, what you need to do first is to draw the profile, lines and a curve, then copy the whole line (use the move tool, hold down control) to a position directly above it (it will snap to a sensible position if you're close enough, and a blue line will appear if you're going directly up.
    You'll then need to draw lines from the top line-curve down to the bottom, from each end-point. when you've done two a flat section will appear, keep going till you're finished. to smooth the piece out you can select the whole thing, right click and select smooth.
    I'll make some pics if the above doesn't make any sense. (which it probably doesn't.)
  18. SuperToadMan
    27 May 2004
    Thank you!!! Ill try this out asap!
  19. Dodge
    10 Oct 2003
    some pics would be great, i seem to be able to make the mesh but then not surface appears
  20. KAMIKAZE-FREAK
    30 May 2004
    tell me what tsja think k? :thumb:
