SketchUp Sketchup Components Collection (SCC) Discussion
Discussion in 'Modding' started by jezmck, 25 Nov 2003.
  1. basti523
    basti523 What's a Dremel?
    24 Feb 2006
    servus...ich hab ma zwei dingens gebastelt...meine ersten! das programm is echt geil, da kann man schön einfach ideen umsetzen :)
    einmal scythe ninja passiv kühler ( nur ungefähr nachbau nach maßen und bildern. in etwa 2 stunden arbeit) axo ja das teil müsst ihr noch runterskalieren in sketchup mit 0,1 dann sind die maße original!
    skythe ninja cpu cooler
    und einmal das gigabyte-GA-8I955X Royal mainboard (atx maße, ungefähr 1 stunde arbeit)
    langt aber voll und ganz um zu schaun obs ins gehäuse passt ;) viel spaß damit!
  2. BradleyKF
    BradleyKF What's a Dremel?
    1 Mar 2006
    Looking for help creating a mod. I can't for the life of me figure out how to get this to work properly.If anybody could PLEASE help me out making some components it would be a great help.
    I need:
    a Cooler Master Hyper 6+ and/or Cooler Master Aquagate R120.
    Asus A8N32-SLI Deluxe and/or Asus A8N-SLI Premium
    Corsair XMS-3500LLPRO (I know there's something close to this already posted, just needs a different side)
    Antec NeoPower HE 550
    Mitsumi 7-in-1 Internal Card Reader
    Western Digital RaptorX
    Western Digital Caviar SE16 500GB
    Plextor PX-760A
    EVGA eGeForce 7800 GTX KO
    Creative Labs Sound Blaster X-Fi XtremeMusic
    D-Link DWL-G520 Airplus Xtreme G
    This is my first major expensive mod, and I want to be able to see how its gunna look before I invest. ANY help would be greatly appreciated. I watched the tutorials, but I'm still having trouble. I can send somebody some excellent images that I already found if they need some and PM me. Thanks.
  3. GuardianStorm
    GuardianStorm Minimodder
    26 Apr 2005
    well i would suggest using the parts already there...someone may have the model you require, but not all of it, so make do with what ya got :)
    as for a raptor....use a hard drive....there already in the scc and they are the same size etc...for other things like sound cards:
    A) draw a box that is the same size
    B) Use another card to make a reperesentation....
  4. BradleyKF
    1 Mar 2006
    I want to get it to look the same tho, not just the same shapes, but haves the image thing going on too. Like the A7N8x Deluxe by CyberShaman. I think you actually fixed it too?
    And to be honest, I'm even having troubles just getting these shape dimensions right, or getting them to go together properly. Like I won't be able to center something properly etc.
  5. GuardianStorm
    26 Apr 2005
    the only thing i fixed withthat mobo was the fact that it was inverted.
    if you so desperatly need a particular component:
    A) Learn sketchup...its easy :)
    B) Send me the component and il model it :p
  6. jezmck
    jezmck Minimodder
    25 Sep 2003
    :rolleyes:
  7. Brubacker
    Brubacker What's a Dremel?
    23 Oct 2004
    FYI , Google has just bought @Last Software ( makers of SketchUp )
    The entire article can be read here
  8. jezmck
    jezmck Minimodder
    25 Sep 2003
    wowzers.
    should have seen it coming really - there is already the Google Earth plugin, and I guess they'll be aiming to model the whole planet!
  9. Brubacker
    23 Oct 2004
    Indeed,
    The next time I've got a spare week I'll start drawing my home :D
    so everyone can virtually visit my home :p
    Incl the details ( like the internal components of the PC systems everywhere in my house and the exact measurements of everything in and outside :D )
  10. djbugiz
    djbugiz What's a Dremel?
    14 Mar 2006
    anyone interested to make an Asetek Vapochill unit,,, pwease...
  11. Jeebus
    Jeebus What's a Dremel?
    27 May 2004
    wow, just think of how easy it will become for burglars to check out your house before they actually break in. They can just print a plan of your house with all the valuable stuff so they wont even have to look for anything! THANKS google!!! :D
  12. jezmck
    jezmck Minimodder
    25 Sep 2003
  13. scooby
    scooby Minimodder
    3 Mar 2004
    Here is my version of the Evercool 120mm Aluminum fan, still working on a 80mm. Still a few more detail and it will be done.
  14. jezmck
    jezmck Minimodder
    25 Sep 2003
    looks great - care to submit it to the SCC?
  15. scooby
    scooby Minimodder
    3 Mar 2004
    Hey jazzle, how are you?
    It would be an honor, just have to clean it up a bit before I can sign off on this.
    Check this one out (still need cleaning up) Dual Dell 2405FPW on a Ergotron stand. I modified the back cause I don't have a real one to model from.
    :D
  16. jezmck
    jezmck Minimodder
    25 Sep 2003
    Looks brilliant.
    As long as the scale's accurate I'll be very happy to add that.
  17. scooby
    scooby Minimodder
    3 Mar 2004
    To my knowledge they are. The fans for sure. I also have a dual Samsung T191
    + 19" LCDs on the same stand and I know thats accurate cause I have them.
  18. jezmck
    jezmck Minimodder
    25 Sep 2003
    Cool - just let me know when they're ready.
  19. hobbs
    hobbs What's a Dremel?
    24 Jun 2005
    are there anyother sites that have computer moddles that you can download for free?
  20. jezmck
    jezmck Minimodder
    25 Sep 2003
    No! Absolutely not! Who told you that? Why would there be?! It's a lie I tell you.
