SketchUp Sketchup Components Collection (SCC) Discussion
Discussion in 'Modding' started by jezmck, 25 Nov 2003.
  1. scooby
    scooby Minimodder
    3 Mar 2004
    @Roswell, You can enlarge any item in SU, just select the artwork (fan) and select your SCALE tool them hold down your "Ctrl" key and it will enlarge the fan uniformly. You will have to adjust the thickness back down to 25mm. I have made 140 fans already if you want.
    @Ener, like this?
    Thanks guys, its a fun project and I'll to keep you posted on it's progress. Here are a few more pics of it.
  2. fev
    fev Industry Fallout
    13 Aug 2003
    does anyone know how to import sketup into solidworks?
    random question i know, just need to find out for a friend who's designing a media centre for mass production
  3. Roswell
    Roswell What's a Dremel?
    21 Nov 2006
    Yeah, thanks would be cool.
    Thanks for the hint about the scale-tool, added it to my buttons, hadn't noticed it before.
  4. scooby
    scooby Minimodder
    3 Mar 2004
    @fev, Solidworks works almost like AutoCad so import as .dwg file.
    In SU:
    File>Export Model>Select the file you want>Choose AutoCAC DWG (*.dwg)>Export
    In Solidworks:
    File>Open>Select your file
    I haven't worked with Solidworks in awhile so I hope that helps.
    @Roswell, PM me if you would like the file.;)
    Scoob
  5. HaoKi
    HaoKi Lleno de anguilas!
    10 Oct 2003
    I really haven't bothered to import anything from sketchup to solidworks in a long time. Instead i have modeled all of the components that i've needed straight in solidworks.
    My Profile On AllTheMods
    There u can see some of the models... Pm me if u want some more info on solidworks component models.
  6. Ener
    Ener What's a Dremel?
    17 Oct 2005
    yeah like that scooby, im gonna try some other stuff too.
  7. Roswell
    21 Nov 2006
    Nm, solved my own problem.
  8. Klekkus
    Klekkus What's a Dremel?
    5 Nov 2005
    I think te page is down =/
  9. Bluephoenix
    Bluephoenix Spoon? What spoon?
    3 Dec 2006
    the solidworks import is correct, even works with 2001
    an nvidia 8800GTX model or another dual-slot GPU would be good, I'm worried about heat transfer/ airflow in the mod I'm currently designing.
  10. jezmck
    jezmck Minimodder
    25 Sep 2003
    Seems fine to me...
  11. Roswell
    21 Nov 2006
    Is there a way to get chrome-look?
    Or any other metal looks than the standard ones for that matter?
    Or just some way to make an object "shine"?
  12. jezmck
    jezmck Minimodder
    25 Sep 2003
  13. Roswell
    21 Nov 2006
    K, thanks,will look into that this weekend.
    Next question :worried:
    As seen in this screenshot, the white thing in the right upper corner is a bolt, how can I make a hole in the black plate, so that it's exact the size and location of the bolthead?
  14. andrew1977
    andrew1977 What's a Dremel?
    22 Dec 2006
    Has anyone made a Thermaltake Kandalf LCS model yet?
    Or a regular Kandalf/Armor with the internal structure modeled as well?
  15. vortex46
    vortex46 What's a Dremel?
    30 Dec 2006
    Hi guys,i'm asking you a huge favor.I need a sketch of the Mozart Tx VE1000BWS for my future modding.I'm not good with sketch up so i'm asking you.Please help me.Thank you all :)
  16. BenJ
    BenJ What's a Dremel?
    1 Jan 2004
    Mate, use the tape measure tool and measure it all very carefully.
    Thats what I have been doing.
    BenJ
  17. Roswell
    21 Nov 2006
    I've solved it otherwise:
    edit component on the panel, that way the bolt is visible trough the panel, then just creating a circle on the panel, trying to get the center of the bolt, Sketchup seems to "see" what you're trying to do and centers it exactly...
  18. Brubacker
    Brubacker What's a Dremel?
    23 Oct 2004
    easy if you know it
    put the bolt right through the black plate.
    then click on it with your right mouse button and choose "intersect with model" now you've got a circle drawn on the black surface with the exact measurements. Now you can push/pull/delete/move/... the circle.
    otherwise you've got to use the measurement tool :)
  19. XteZi
    XteZi What's a Dremel?
    8 Sep 2006
  20. .:ALOA:.
    .:ALOA:. What's a Dremel?
    23 Nov 2005
    aloha, dus someone know where i can find the Lian Li PC-V300??
    i wanna make a mod, but i wanna draiw him first on my pc...
    (sorry for my engelish..)
