SketchUp Sketchup Components Collection (SCC) Discussion
Discussion in 'Modding' started by jezmck, 25 Nov 2003.
  1. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    No I'm not building it but it would be sweet if I could. On Friday I drop a V8 (with Hilborn intakes) in the back and got the back sup. done and was just starting the front sup.
    Like I said this is just a 3d project for CAD class
  2. The_Beast
    21 Apr 2007
    I'm thinking of designing a RC buggy and building it, if I find time
    the scale shoud be around 1:8 or 1:10 using 1/4" tubing
  3. Hasle
    Hasle nohasslemods›
    27 Sep 2004
    Silverstone TemJin
    Has anyone done a Silverstone TemJin SST-TJ07, perchance? Otherwise I'll be doing one in the near future.
  4. rchiileea
    rchiileea Minimodder
    11 Jan 2008
    been slowly making a tj07 model when i have the time, i used the one on google sketch up (the oversized one) then resized it a bit via adjustments for correct size. its not finished but you are free to do with it as you please.
    HERE
  5. The_Beast
    21 Apr 2007
    I have updated pic of the buggy
    I'll upload them later today
  6. scooby
    scooby Minimodder
    3 Mar 2004
    Can't wait Beast, looking forward to it.:thumb:
    @rchiileea, great work on the resize. I wish I had the case with me so I can do a model of it...anyone want to send me one.LOL!!!!
  7. The_Beast
    21 Apr 2007
    you got it
  8. jezmck
    jezmck Minimodder
    25 Sep 2003
    steering?
    non-independent front suspension?
  9. Teyber
    Teyber ******
    18 Mar 2007
    who need steering???:grr:
  10. scooby
    scooby Minimodder
    3 Mar 2004
    Google SketchUp 6 / Pro 6 Update:
    http://sketchup.google.com/gsu6/download.html
    Release Notes -Google SketchUp 6 for Windows - Maintenance Release 4
    last updated 12/12/2007
    Please note that these release notes apply to both versions of Google SketchUp: Google SketchUp 6 and Google SketchUp Pro 6.
    SketchUp version 6.4.112
    LayOut version 1.0.1199
    For Additional Information:
    The Google SketchUp Help Center has articles that will answer your questions and provides a search capability so you can look for issues of interest. To visit the Help Center, feel free to check out http://sketchup.google.com/support/
    Our download page at http://www.sketchup.com/?section=downloads provides you with some additional software, including some Ruby scripts and additional components that can be used with SketchUp Pro 6.
    The 3D Warehouse provides models from other SketchUp users that you can download and use! You can also place your models in the warehouse at http://sketchup.google.com/3dwarehouse/ for others to see!
    System Requirements: Please visit http://sketchup.google.com/support/b...y?answer=36208
    AutoCAD 2007 Support:
    The major thrust of maintenance release 4 is support for AutoCAD 2007 DWG import and export.
    Other Fixes
    We also made a few other fixes for localization purposes.
    There was one Ruby fix that also supports the AutoCAD 2007 initiative which is the ability to suppress results dialog box on DWG export.
    Beast, I'm sure your still fine tuning your buggy but I must say it sure coming along nicely. I really like your headers...looking good bro.
    Jez....you crack me up dude!!!!
    BTW, I have been at XtremeSystems.com forum and I have seen a few guys using SU modles from Jez's SCC collection, I even saw one guy using my Asus Maximus board and he gave Jez and I a shout out. I thought that was just cool.
  11. sheninat0r
    sheninat0r What's a Dremel?
    28 May 2007
    What's in that update? I still want them to fix circles...
  12. jezmck
    jezmck Minimodder
    25 Sep 2003
    in what way are they broken?
  13. scooby
    scooby Minimodder
    3 Mar 2004
    Added Release Notes to the post. You can also fine it in the link I posted above, just open the link and look for "Release Notes".
    @sheninat0r, what problems are you having?
  14. sheninat0r
    28 May 2007
    Well it's not a bug per se, I just don't like how the circles are made of short straight lines - for some reason it annoys me a LOT... [yes, im weird. dont start.]
  15. Asulc
    Asulc Minimodder
    18 Jul 2007
    Technically everything is made of little straight lines, but that is just me. I wouldn't worry about it, cause I doubt it will be fixed.
  16. jezmck
    jezmck Minimodder
    25 Sep 2003
    It's not a bug at all.
    You can tell it to use more segments if that would appease you ;)
  17. The_Beast
    21 Apr 2007
    I wish, it's due before finals which is wensday/thursday and I still have to do some technical drawing for it
    the back is independent :thumb:
    that is what I was thinking :thumb:
    no time to fine tune :wallbash:
    I'm at 274 parts :thumb:
  18. scooby
    scooby Minimodder
    3 Mar 2004
    Did a watercooling barb with treads and "O" ring details.
    Jez should have it up soon.
    Scooby
  19. The_Beast
    21 Apr 2007
    very nice :thumb:
  20. jezmck
    jezmck Minimodder
    25 Sep 2003
    very nice indeed. is up, despite the thread being fake! ;)
