Modding Sketchup Components
Discussion in 'Modding' started by jezmck, 19 Nov 2003.
  1. jezmck
    jezmck Minimodder
    25 Sep 2003
    Hi everyone,
    I am currently planning my case, and am using Sketchup to try out layout ideas.
    I have been able to model some parts easily enough, but was wondering how to make a component set, or whether one already exists. I have seen the few pieces here but was hoping there are a few more around...
    These could be useful to all of us, don't need to be highly detailed like the 3DS Max stuff on that thread, just the right size etc.
    If anyone knows of, or has, further components could you please post them here?
    Thanks in advance... :)
  2. M_D_K
    M_D_K Minimodder
    3 Apr 2002
    What do you need i've got quite a few components, i will post them once i've finished my top secret project that only a handfull have whitnessed :(
    ooops i told you too much your now going to die lol :p
    anyway i can draw little things if you like.
  3. jezmck
    jezmck Minimodder
    25 Sep 2003
    I suppose I just want/need the standard stuff like:
    (ATX)Mobo, CD/DVD Drive (Slot/Tray), Floppy, PSU, GPU, HSF, 60/80/120mm fans.
    if the mobo could just have slots to show the positioning for cards that'd be cool.
  4. japala
    japala What's a Dremel?
    8 Dec 2001
    I hope that people doesn't make the models too detailed. No point on having all the pins etc. modelled for a cd-drive because it all eats a lot of CPU power to work with and doesn't contribute that much to the end result. I think that the whole idea with Sketchup is to be able to avoid autocad and all the other "heavy duty" programs and their features. Simple, clean and functional models please. :)
    Here is my contribution. Made this after my old Ti4200 card but should work dummy for any display adapter.
    Download
  5. jezmck
    jezmck Minimodder
    25 Sep 2003
    japala - thanks for the GPU
    re detail: yeah - all we really need is objects the right shape and size
  6. raxxo
    raxxo What's a Dremel?
    24 Jan 2003
    Does anyone know if sketchup is compatible with SolidWorks 2002 and later... if so I´ve got a bunch...
  7. jezmck
    jezmck Minimodder
    25 Sep 2003
    afaik, sketchup can only import DWG/DXF files
  8. raxxo
    24 Jan 2003
    hmm... i can export to dwg... so i can probably fix some...
  9. jezmck
    jezmck Minimodder
    25 Sep 2003
    that would be great if you can, thanks :thumb:
  10. BlackMan
    BlackMan Minimodder
    12 Sep 2003
    what program are we using here and does anyone know where i can download it from, sounds like a very useful program
  11. jezmck
    jezmck Minimodder
    25 Sep 2003
    we're using Sketchup.
    it's a great program designed to be used to sketch ideas, but in 3D, have a look at the site
  12. jake^the^cake
    jake^the^cake What's a Dremel?
    1 Oct 2002
    I got a watertower if you want, its nice :)
  13. El Nosba
    El Nosba What's a Dremel?
    22 Sep 2003
  14. jezmck
    jezmck Minimodder
    25 Sep 2003
    excellent, thanks.
  15. jezmck
    jezmck Minimodder
    25 Sep 2003
    just to let everyone know that I am working on a new thread which will contain everything i have so far, once i have got permission from the sketchers...
  16. raxxo
    24 Jan 2003
    can you save in dwg in sketchup to ?
    if so i can import them in solidworks
  17. jezmck
    jezmck Minimodder
    25 Sep 2003
    I believe so
  18. dezaster
    dezaster What's a Dremel?
    11 Aug 2002
  19. jezmck
    jezmck Minimodder
    25 Sep 2003
    thanks - will have to see if i can use some of those...
  20. jezmck
    jezmck Minimodder
    25 Sep 2003
