Planning Sketchup help for case idea
Discussion in 'Modding' started by BBEG, 16 May 2013.
  1. BBEG
    BBEG What's a Dremel?
    20 Oct 2011
    I've got an idea for a scratch build to house an mATX motherboard, two GPUs, a 360 rad, 120 rad, and full size ATX PSU in a space .04L bigger than the internal dimensions of a Prodigy. The problem is, I have absolutely zero talent in Sketchup to lay it out on screen and see if the fit of everything will actually work like it does in my head. Is there any specific place in the forum where I can request help fleshing this out? If posting here is fine, I can do that too.
  2. TheP
    TheP What's a Dremel?
    9 Oct 2012
    Well...i bet there will be some readers here who can help you.
    But even if you have "no talent" with sektchup try it.
    I did the same thing and after some models (the first few where dimensions away from perfect) you get a feeling of how much space you need for fittings, tubes, cable-management and so on.
    And - thats how i think - the feeling of doing the whole process from beginning to finish by yourself feels the best.
    Just make a few sketches and post them here. The community will help you
  3. MightyBenihana
    MightyBenihana Do or do not, there is no try
    8 Sep 2011
    Sketchup is really easy to learn and there are some great tutorials on youtube should you have a specific problem. After about 5 hours of messing around you will be more than capable of creating this.
    Also there is the 3D warehouse. Here many models have already been created, such as PUUs, GFX cards etc which make the whole thing even easier.
  4. jrs77
    jrs77 Modder
    17 Feb 2006
    Just look at the collection of SU-files over at http://scc.jezmckean.com/
    Then fire up SketchUp, import all the parts you want to use (or similar parts to get an idea of their dimensions) and then arrange all the parts to see if they fit into the box you have in mind.
