In sketchup, how do you "join" multiple objects so that when you move them, they move together? Im trying to use the 120 mm fan in the sketchup library, but moving the blades individually isnt working.
In some versions triple-click is supposed to select multiple objects. Not sure if it will help you??? Good luck http://www.findingfacts.com
