Planning [Sketchup] What do you think of my case design? (need input)
Discussion in 'Modding' started by koksy, 16 Oct 2009.
  1. koksy
    koksy What's a Dremel?
    23 Jul 2009
    For starters, it's made for air cooling, but has enough space for future water cooling.
    Lot's of images first.
    4 iso angles
    http://www.wowbucket.com/uploads/1255752822.png
    http://www.wowbucket.com/uploads/1255750059.png
    http://www.wowbucket.com/uploads/1255740486.png
    http://www.wowbucket.com/uploads/1255736289.png
    4 front angles
    http://www.wowbucket.com/uploads/1255779847.png
    http://www.wowbucket.com/uploads/1255758385.png
    http://www.wowbucket.com/uploads/1255826203.png
    http://www.wowbucket.com/uploads/1255756301.png
    2 device slots, 1 for dvd/bd and 1 for fan controller.
    top
    http://www.wowbucket.com/uploads/1255763676.png
    Just a RIIE with an IFX-14.
    3 hardware angles
    http://www.wowbucket.com/uploads/1255809770.png
    http://www.wowbucket.com/uploads/1255736803.png
    http://www.wowbucket.com/uploads/1255806621.png
    The parts to hold the hardware will be made of either polycarbon or alubon.
    skeleton
    http://www.wowbucket.com/uploads/1255760388.png
    The skeleton will be made with anodized aluminium.
    The idea is to provide optimal passage for the air to cool the hardware, and to keep the cable management as nice as possible.
    Any ideas for improvements or anything else?
  2. jhanlon303
    7 Sep 2006
    Now let everybody see this. [ img] before and [ /img] after. Take out the space
    john
    /edit
    Oh and it's nice too.
  3. koksy
    23 Jul 2009
    The images are quite big, so I thought I'd just link them instead. There should be a spoiler option, best of both worlds.
  4. FrooP
    FrooP can I eat this?
    24 Oct 2007
    you really want to have your case this big? i mean the concept, the cable channels and everything seems very good, but id say scale the case down a bit
  5. koksy
    23 Jul 2009
    I have tried to make it as small as possible, but it's hard to make everything fit and still have proper cable management, and also space for future water cooling.
  6. mrdbristol
    mrdbristol Voided my warranty years ago
    8 Aug 2008
    Using the design for the HDD brackets ( it looks like Mountain Mods triple HDD bracket ) , you will be blocking the inner 2 drives on each bracket from airflow from the fans.
    Rotate the mounting holes 90 degrees and air will flow over and through all the drives.
    :thumb:
  7. koksy
    23 Jul 2009
    Yes, it is the hdd holder from MM, slightly modded :D I have thought of that, but have not found any good solution yet. Maybe something simple the the PSU holder will do.
  8. dave_c
    dave_c Minimodder
    31 Jul 2009
    hay, looks good,......big, but good
  9. mrdbristol
    8 Aug 2008
    If you're only using 2 sets, why not mount them on the 120mm fans as they are designed to ?
    Have 1 of the 120s as an intake and the other as an exhaust and you have a through flow of air over all 6 HDDs.
  10. koksy
    23 Jul 2009
  11. mrdbristol
    8 Aug 2008
    Much better airflow and will hide all the cable connections on the back of the HDDs.
    :thumb:
  12. stuartwood89
    20 Aug 2008
    I would comment, but I just see red crosses, I think that's my work blocking the images though :(
  13. koksy
    23 Jul 2009
    edit: We should have a delete button...
  14. koksy
    23 Jul 2009
  15. koksy
    23 Jul 2009
    Think I could make this case out of wood?
  16. bigsharn
    bigsharn Officially demotivated
    9 May 2008
    Easily, you'd need plenty of screws or glue and dowelling though... and the motherboard tray would pretty much have to be made of metal or plastic
