I have someone who I'm trying to help connect over SSH to his university account. He uses Sky Broadband as ISP. Do they block port 22? (This is aimed at yodasarmpit aswell )
I don't have an official Sky answer, but yes I believe port22 is blocked. The Sky router also has a modified firmware which has had the VPN setup section removed. Sky broadband is marketed as a home product not suitable for business use, which SSH/VPN is normally associated. I've had a quick check on mine and regardless of what I do with the router, port22 appears to be blocked hmmm
Yoda, the websites that list all the default passwords for the sky routers seem to all be wrong now, has sky changed the password? and you wouldnt happen to want to whip it my way so that my friend can get the info off it to use his own kit?
Turns out it's not Skys fault Yoda. Well it kinda is, the ADSL IP range that Sky gives out were part of an IP range which was blocked by the University due to troubles.
The default router login/password is still : Username : admin password : sky This is to access the routers firmware/admin page To use another router the login details ase : Username : yourmaccode@skydsl Password : random number You need to telnet into the router to retrieve the password, I'll get you the info when I get home.
Right, to get the user name and password from your router, to then enable you to use them on another router of your choice, follow the instructions below. Open your favourite web browser and copy this into the address bar : Code: http://192.168.0.1/setup.cgi?todo=ping_test&c4_IPAddr=%26/bin/grep+ppoa_+/tmp/nvram+%3E+/www/netgear.cfg When asked for user name and password type in : Username = admin Password = sky You will get a page that reads "Usage: ping [OPTION]... host" Now copy the below into your browser address bar Code: http://192.168.0.1/netgear.cfg This will then download a config file, "netgear.cfg" Open the file with word pad (wordpad will retain any formatting unlike notepad) You should see some text like this below : pppoa_username=001122aabbcc@skydsl pppoa_password=a0b1c2d4e5 pppoa_idle=0 pppoa_ipaddr= The rest is self explanatory.
Great That's great! Thank for sharing that with us. So, If I were to use a Linksys or another new Netgear router, I can just use the above technique to extract the username/password, and use this for making it work with my current Sky BB connection.
