A/V Sky TV on my PC
Discussion in 'Hardware' started by Necrosis101, 2 Jun 2006.
  1. Necrosis101
    Necrosis101 What's a Dremel?
    2 Jun 2006
    Hello. I need some help. I want to have sky installed in my house, but i want to be able to watch it through my computer. What do i need? And what do i have to do?
    My computer spec is:
    AMD sempton 3000 processor
    1.80Ghz
    1GB Ram
    Nvidia Geforce 6100
    I know its not great.
    Thank you
  2. kenco_uk
    28 Nov 2003
    Afaik, their aren't any 'digibox-on-a-card' type things for PC's, as digiboxes use a proprietary encoding/decoding chip and are too tight to licence it out to PC card manufacturers. You could build a media centre PC, using Windows MCE or MythTV, etc.
  3. SpeedFreak
    SpeedFreak What's a Dremel?
    28 Mar 2003
    1 word:
    'SlingBox' - Google it.
    It costs £179 and does exactly what you want....
  4. ozstrike
    ozstrike yip yip yip yip
    19 Sep 2004
    You can watch it and record it on your PC indirectly by using a TV card and plugging the output of the Sky box into the input of the TV card. However, you won't be able to access the Sky Guide directly through your pc, and you won't (easily, although I expect it's possible with some custom hardware/software) be able to make your PC change the channel. This isn't so bad, although the drawback of this is that if you set your PC to record something, you have to set the Sky box to the right channel and leave it on before you leave.
  5. SpeedFreak
    28 Mar 2003
    I'll say it again
    'SlingBox'
    it allows you to change channel. And watch your sky wherever you are in the world with a decent internet connection!
    Say it with me! 'SlingBox' - doesnt it just roll off the tongue...
  6. seebul
    seebul Minimodder
    9 Aug 2005
    Just get a tv tuner card with an AV input, then plug your digibox into that, you can acess the guide and everything that way.
  7. kenco_uk
    28 Nov 2003
    Hopefully your words aren't falling on deaf ears, SpeedFreak :) I sometimes get that in threads, too.
    Never heard of this Slingbox though.. hmmm.. :idea:
  8. ozstrike
    19 Sep 2004
    Sorry bout that Speedfreak. Guess I should have refreshed again before posting. After looking at the Slingbox, it can indeed do what is needed. However what I posted still works if you do not want to spend extra money on the Slingbox.
  9. herbs
    herbs Nobody but us chickens
    7 May 2001
