News Skylake-X Direct Die Frame aims for safer IHS-free cooling
Discussion in 'Article Discussion' started by bit-tech, 19 Jan 2018.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. Guest-16
    Guest-16 Guest
    That's a great mod. Now it needs it for 1151 CFL
  3. Guest-23315
    Guest-23315 Guest
    £62 ?!???
    EDIT.. i suppose if you're de-lidding you can afford it.
  4. Anfield
    Anfield Multimodder
    15 Jan 2010
    Nice product, just a shame it is "necessary" in the first place to get proper cooling.
  5. Vault-Tec
    30 Aug 2015
    Not so much delidding but what you are delidding. If you are delidding a £1500 CPU then £62 is a drop in the ocean.
  6. GeorgeStorm
    16 Dec 2008
    Nice, some guys run direct die setups for ln2 with gains of 50-100mhz it seems, makes sense for it to filter down to ambient.
  7. TheMadDutchDude
    23 Aug 2013
    These won’t become a thing for CFL simply due to the substrate being way too thin. It bends much easier than Haswell or previous generations and has proven to be a massive issue with Skylake when direct die cooling is used.
  8. Byron C
    Byron C AKA “Sticky Equilibrium” on weekends
    12 Apr 2002
    Just like the old days of P3's & Athlons, when crushed cores were common... *nostalgia*... ;)
    jb0 and Vault-Tec like this.
  9. TheMadDutchDude
    23 Aug 2013
    That’s why this bracket exists... to stop that. XD
  10. Byron C
    12 Apr 2002
    The amount of crushed cores I used to see is probably why they stopped shipping CPUs with bare dies and started adding heat spreaders.
  11. TheMadDutchDude
    23 Aug 2013
    Yeah, that’s pretty much exactly the reason. However, it’s impossible to crush the core with this bracket.
  12. jb0
    jb0 Minimodder
    8 Apr 2012
    I never really understood why they didn't make a shim a standard feature. It seemed an obvious pack-in for bare-die parts. And then they went to a full lid instead of a shim, just out of spite I assume.
  13. Vault-Tec
    30 Aug 2015
    Some one made one of these for Ivy. I forget who now, might have been MSI or Coolermaster?
    But delidding was nowhere near as popular as most just stuck with their Sandy CPU.
  14. TheMadDutchDude
    23 Aug 2013
    It was MSI, VT. :)
Tags: Add Tags
