Case Mod - In Progress Skyrim: Dwemer's Build - Big Update
Discussion in 'Project Logs' started by TheGreatSatan, 2 Sep 2013.
  1. TheGreatSatan
    TheGreatSatan Member for 17 years!
    5 Aug 2005
    Have you ever played Skyrim? If you have, then you've seen what the Dwemer race is capable of. They are an ancient lost race of elves who built machines and robots out of copper that were powered by steam.
    Makes you wonder, if Dwemer's ever got around to building PC's. What would they look like? Edit Text
    "A race of stonecutters, artisans, and engineers. They invented machines and built elaborate underground cities where they researched powers to rival the gods themselves. And then, at a time we are still not sure when, they disappeared. The whole people, all at once. Leaving behind only their works." - Calcelmo
    I've been wanting to do my own Prodigy case mod for the last 6 to 8 months at least. I will be converting it to mATX too, and I know I'm not the first to do this.
    Regardless, I need to do my own version!
    I like the footprint, but hate this case
    I removed everything that can be taken off with a screwdriver
    Then about ten rivets to remove the drive cage
    I need an mATX frame.....
    Next to the Asus Vento, this is the ugliest case. Although it is only $13!
    Besides the frame, I get a crappy 230 Watt PSU for testing cathodes and fans
    Here's what I needed
    I'll be putting the motherboard in the middle of the case and the PSU behind the motherboard tray. I'm also pushing it against the rear of the case, so I can fit a 200mm high air flow fan as an intake
    The case came with a handy PSU back plate which lets me plan out where it will go
    Here's the 200mm NZXT fan I'm going to use. It moves 160 cfm's!
    I'm going to be putting mesh over the top of the fan, so the mesh that's there now has to go!
    The back plate and PSU holes get cut out too
    I'll be adding Bondo soon
    I wanted to see how it looked, so I put a power supply in
    This is not going to be the back anymore and it's got to go
    Here's the mesh I'm using
    But I have to cut it to size
    And neatly cut the edges
  2. Azariel
    Azariel What's a Dremel?
    23 Oct 2008
    Haven't played skyrim, but a quick google shows that that race has enough distinct features to make a great case :) Very curious what you will make of it!
    And you should really keep a 'mod counter' in your signature if you ask me :p
  3. Cheapskate
    13 May 2007
    @Azariel - There's a text limit on signatures.:lol:
    I don't think it counts as a prodigy mod if you discard everything but the basic frame dimensions.
    $13 + a power supply? China doesn't have a word for "metal foil" do they?
  4. jrs77
    jrs77 Modder
    17 Feb 2006
    Why didn't you just buy the µATX Prodigy-M ?
  5. jokkos
    jokkos too busy to mod *sigh*
    10 May 2005
    Another Prodigy...damnit this case is growing on me...
    What would be the fun in that? :dremel:
  6. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    Don't let it, my wife has one and I'll never touch another one. It's crap. It took so much modding just to put in a power supply that was decent that I could never recommend it again, not even for modding.
  7. TheGreatSatan
    5 Aug 2005
    I can't find it
    That's why I don't have "Prodigy" in the title
  8. VipersGratitude
    VipersGratitude Multimodder
    4 Mar 2008
    Excellent premise...can't wait to see the execution
  9. TheGreatSatan
    5 Aug 2005
    I put a crappy dead board in so I get the measurements right
    Like this exhaust fan.
    The fan grill is just to measure out the hole
    No Dwemer construction is complete till you add copper
    So, I picked up this 5 foot piece of copper
    And cut out two pieces for the bottom of the case
    I also picked up some elbows and t-sections
    I pieced together an "H" to start
    Now that it's set on the bottom of the case, I know it needs to be a little taller. I want it to lift the case about two inches off the surface it sits on just like the previous feet did
    I'm not sure yet, but I may use this shower drain as a fan grill
  10. TheGreatSatan
    5 Aug 2005
    I picked up four dowels
    and candlestick holders
    First I drilled out the candlestick holders
    Then I ran a threaded rod through the holders into the rod
    Then taped it so the glue could dry evenly
  11. kenco_uk
    28 Nov 2003
    Do-be-doo.. copper piping, cool! Heh, gold fan, nice!
    Dowels and.. candlestick holders? :eyebrow: The what now?
  12. DeltaFX
    DeltaFX What's a Dremel?
    4 Aug 2006
    Dwarves. Not elves. Ancient lost race of dwarves.
    Copper piping for the win.
  13. Darkwisdom
    Darkwisdom Level 99 Retro Nerd
    27 Aug 2011
    Technically the Dwemer were an elven race, like wood elves, dark elves, high elves and Orcs; they all descended from a common ancestor.
  14. TheGreatSatan
    5 Aug 2005
    While they dry, I mark and drill holes for them
    The dowels are all dry now
    Now it's time to add them to the case
  15. TheGreatSatan
    5 Aug 2005
    I got my 2nd Prodigy!
  16. TheGreatSatan
    5 Aug 2005
    The 2nd one needed to be stripped down too
    Then dropped it on top of the pillars!
    Then secured it with bolts
    It will need a bog fan too
    But first they both need to match the theme
  17. TheGreatSatan
    5 Aug 2005
    I painted the pillars copper
    Then I started to rock out the case....
    I picked some hydrocal and rock molds
    And after hours of screw-ups and dry time, I made quite a few molds. They're heavier than I expected they would be
    Here's a sharpie next to it so you can see how thick they are
  18. AlienwareAndy
    AlienwareAndy What's a Dremel?
    7 Dec 2009
    Awesome stuff !
  19. TheGreatSatan
    5 Aug 2005
    At this point it's OK to mount the top case
    Now that the first coat of paint has dried on the rocky panel
    I can start planning where the copper pies go. More rock coming too!
  20. AlienwareAndy
    7 Dec 2009
    This is really cool. It kind of reminds me of making scenery for my train track :)
    Good going dude. I always like it when people do game tribute builds. One day I'll finally do a Fallout 3 build :)
