Cooling sladesurfer's new water cooling setup
Discussion in 'Hardware' started by sladesurfer, 25 Oct 2006.
  1. sladesurfer
    sladesurfer What's a Dremel?
    14 Jul 2006
    Here are some pics:D
  2. r4tch3t
    r4tch3t hmmmm....
    17 Aug 2005
    Nice, what reservoir is that?
  3. Gravemind123
    Gravemind123 avatar not found
    26 Aug 2006
    That's really cool looking! If I had the time or money I would try something like that....
    I like the radioactive look of the coolant!
  4. silentphoenix
    silentphoenix What's a Dremel?
    1 Sep 2004
    Looks good.... but errrrr... wheres your pump?
  5. Guest-23315
    Guest-23315 Guest
    i think you're going to get some bad (ie. negative temps with that)...
    the reason is the exhasut from the PUS is going straight onto the the rad....
    i would try and move it some how... like mounting it with the barbs almost on the floor or the like.
  6. pdf27
    pdf27 What's a Dremel?
    6 Jul 2006
    Fans are usually mounted sucking, not blowing, so that rad should be getting cool external air.
  7. sladesurfer
    14 Jul 2006
    Here's my set up:th_coolio:
  8. Firehed
    15 Feb 2004
    Hmm... that's a very valid question. I can't find one anywhere o_O
    Anyways, nice res there. Nice and clean overall :)
  9. n00btard
    n00btard Go away
    23 Jul 2006
    saw it on XS, it's at the back.
  10. sladesurfer
    14 Jul 2006
    Got a new card!!
