SlaterSpeeds 'Liquified' - Update 09/08/04 - Stage2 Started!! (Painting)
Discussion in 'Project Logs' started by slater, 9 Feb 2004.
  1. fillip
    fillip What's a Dremel?
    9 May 2002
    oooooh that looks nice... you know, it's my birthday, would you like to give me your lurvely new waterblock?!?! :naughty: :naughty:
    thats sweet man, excellent work.
    .: Fillip :.
  2. Spotpuff
    Spotpuff What's a Dremel?
    16 Feb 2004
    OK how in the hell did you get the little "grooves" on the inside of the holes? I mean, if you had to use a bit, wouldn't the bit pieces be too big to fit into hte hole :confused:
    *sigh* This is what I get for not having a drill press I guess :blah:
    Still, that is one damn fine looking block. I didn't know where the design was going until that last pic with the three holes :)
  3. Luhny
    Luhny What's a Dremel?
    12 Feb 2003
    read the page before this #32. he used a machine and cut them
  4. slater
    slater Mummy Says Im Special
    18 Apr 2003
    Do you mean the threads ?? i made them using a tap :rock: :confused:
  5. Spotpuff
    16 Feb 2004
    Yeah the threads; I think that's what they're called. The things that barbs screw into to attach the tubing. :dremel:
    Edit: Just wondering why the middle hole isn't cut through all the way, but just has a slit?
  6. dudeyourmomiscute!
    dudeyourmomiscute! What's a Dremel?
    14 Dec 2003
    why does the center hole look like it's gonna just add more unwanted pressure and restrict water flow..
  7. isisfreak
    isisfreak What's a Dremel?
    19 Jul 2003
    Looking good, I'll be watching this one. :rock:
    More pressure.
  8. 3N1GM4
    3N1GM4 What's a Dremel?
    23 Jun 2003
    the water block looks good... hope it works out nicely...
    as i too love the orange on that case... keep it up
  9. slater
    18 Apr 2003
    Its there to speed up the water as it flows through the channels. This is quite important to the design of the block as if it is not there there is a dead spot of water over the cpu die and in the bottom of the channels.
    The dead spot would degrade performance. :nono:
    ps. I should be making a start on the Res and shroud 2day :thumb:
  10. Da_Rude_Baboon
    Da_Rude_Baboon What the?
    28 Mar 2002
    Looking good! :rock:
    I'm no expert on watercooling but you might want to post your design on the extreme cooling board to get some feedback on your block design and the layout of your loop.
  11. Fr0z3n
    Fr0z3n What's a Dremel?
    21 Oct 2003
    Very nice job on the waterblock. Lots of people have made really nice ones latley. Yall should make lots and sell them. :naughty: Cause I would sure buy some.
  12. Pygo
    Pygo Rick Relixed
    26 Jan 2003
    Yeah, I think I would buy that block from you as well, as long as it fits a s478 setup. But it looks like to me you have an AMD setup there. A VIA chipset on I think a Gigabyte 7VAXP mobo... what are your specs of the system?
  13. slater
    18 Apr 2003
    Thanks guys :)
    Yes im using an AMD system but im not going to use the board that is in the pics. It is more or less dead anyway, something to do with the AGP so it may still work but only with pci gfx!! :wallbash::D. The system i will be using is in my sig.
    I may look into manufacturing a few more blocks after i finish the rest of the system but i doubt i can do it very cheaply. That one took me a couple of days straight work. I figure if i make 10 at a time i could do about one or two a day.
    Just out of interest how much would you be willing to pay for one?
    ps. I started the shrouds 2day so will get some pics up in a couple of hours their looking good!
  14. Pygo
    Pygo Rick Relixed
    26 Jan 2003
    um. I'm not sure... the metal blocks cost money how much do they cost? and then there is labour. I would want one doen for a socket 478 p4, not an Athlon. If you can't make it for a s478, then I will :waah:. but then again, the shipping will be harsh, since I live over the pond in Canada. Also, I would want o put four of these: Peltier link.
    and of course another slab of copper underneith those, at least 1/4" think.
    What do you think would be a fair price? I don't know to much about labour and stuff, and how hard it is to do that. I know it will work out to more than $10 an hour cdn$.
    To bad I don't have an AMD system eh :(
  15. Wicked Li'l Bender
    Wicked Li'l Bender What's a Dremel?
    9 Nov 2003
    Very Important!!!!
    Please look into the how to section about anodizing or take the alum part to get it annodized so you you don't have a nasty bimetalic corosive reaction inside your block.... But other than that, Looks awesome!
  16. slater
    18 Apr 2003
    lol you worry too much :lol: . Im going to get it anodised (or possibly have a go myself depending on what the price is) but im not doing it yet cous ive got about 5 or 6 other blocks and a res to do!
    I will prob get a quote for the res and cpu block first and then get the rest done later that way i can use the cpu loop before i make all the other blocks
    I have read alot about doing it at home so i may try that if i can get hold of some sulfuric acid on the cheap :thumb:
    Edit: Im not sure pygobombe. It would be easy to make one for a p4 but it would have to be a totaly differant design to work with a peltier. the meterials would probably come to around £30 for copper alu and anodising or i may be able to do an all copper version but thats just a estimate. lobour is the killer where i work we charge about £20 per hour for labor so a day works out to about £200 and thats alot! if i made a batch then that price would come down but for a one off then it would be very high.
    But like i say i will look into it a bit more when ive finished this project. At the mo i just dont have time. :(
  17. Pygo
    Pygo Rick Relixed
    26 Jan 2003
    ok.. I think I would want all copper. but not at that much... I respect your work and all. but I can't aford that, so I guess I'll let you look into it a bit more.
    and for time, go ahead and do it right, I am in no rush for water cooling right now. I look forward to seeing your project finished :)
  18. slater
    18 Apr 2003
    Thats kool :D i dont expect anyone to pay over £100 for a waterblock or eaven over £50 relly unless it was a cascade beater, eaven if it is a one off its just not worth it.
    But nm on with the log and the shroud pics
    Back :
    Not finished yet but getting there. Im going to fill up some of the minor imperfections with body filler and then paint them and the core.
    And yes they are aluminum and are welded. :thumb:
  19. Providence
    Providence What's a Dremel?
    23 Jan 2004
    Wow, did you do the welding yourself? If so, that's great work!
    I can't wait for some paint on that heater core...the whole thing is really fugly. Is there an advantage to using a heater core versus a radiator sold by Black Ice?
  20. slater
    18 Apr 2003
    Yeh i did it myself with the TIG welder at work. Im still lurning but after alot of practice goes i finaly managed to get it to weld. It was very hard cous the alu is superthin.
    The heatercores are alot better for performance than a BIX or simlar they have alot lower flow resistance and alot more surface area. :thumb:
