SlaterSpeeds 'Liquified' - Update 09/08/04 - Stage2 Started!! (Painting)
Discussion in 'Project Logs' started by slater, 9 Feb 2004.
  1. Pygo
    Pygo Rick Relixed
    26 Jan 2003
    I see now. But yeah, the res.
    Good luck with her. don't forget to wet her first (put water in the cooling system) and take lots of pics doing it ;)
  2. slater
    slater Mummy Says Im Special
    18 Apr 2003
    Getting there! :thumb: Only thing missing is the filler cap for my res!
  3. slater
    18 Apr 2003
    Im very happy with it right now (excuse my crappy welding on the res its the first time i had tryed going round in circles) :thumb:
  4. olv
    olv he's so bright
    23 Sep 2002
    i'm loving that core/shroud combo, looks the dogs danglies!
  5. Hephaistus
    Hephaistus What's a Dremel?
    11 Mar 2004
    damn that heatercore looks very nice , really Wooooow.
    congrats. :rock:
  6. benje
    benje What's a Dremel?
    4 Feb 2002
    I can see you've put alot of effort into this, and its original and damn smart.
    Bl00dy good job sir!
    Cudos to you for actually making these parts youself, makes you stand out from the croud of "click-and-buy" ready parts modders, myself included
  7. slater
    18 Apr 2003
    Thanks guys :thumb:
    If you think this makes me stand out you should see what i have planned for stage 2 ;)
  8. mopery
    mopery What's a Dremel?
    22 Feb 2004
    Awsome!
  9. dom_
    dom_ --->
    4 Jan 2004
    stage 2? it gets more extreme! :rock:
  10. STellY
    STellY What's a Dremel?
    24 Aug 2003
    that shroud sure does look great now.... good work on it
  11. slater
    18 Apr 2003
    Oh yes! notice the res has another 2 inlet/outlets ;)
  12. HQ08-Modder
    HQ08-Modder What's a Dremel?
    14 Nov 2003
    Damn thats a very nice shroud heatercore combo.
  13. slater
    18 Apr 2003
    So whats next i hear you ask!
    NorthBridge
    Mosfets (NF7)
    SouthBridge
    :thumb:
  14. olv
    olv he's so bright
    23 Sep 2002
    Looking nice, whats the first block? i assume the second is for nf7 mosfets and third is gfx/nb? Hmmm my theory is that the nb and mosfet will use smaller ID tubing and run off a slitter or something and the cpu and gfx blocks will use 1/2"? hmm whatever it is looking good,
    how much for one of those mosfet blocks ;)
  15. Kauder
    Kauder What's a Dremel?
    4 Apr 2004
    Yeah, you could have taken some time to write what they are... Though, this project ROCKS!!!!! :rock:
    Why are you using both alu and copper? I think copper is beautiful as is...
  16. slater
    18 Apr 2003
    lol
    the 1st is Northbridge
    the 2nd is Mosfet (NF7)
    the 3rd is Southbridge
    I will probably do a PSU and GFX block but i dont relly want to yet because i will be upgrading them soon. Possibly hdd aswell one day but for now im going to stick with the mobo blocks.
    Im using alu cous its cheaper, I have tons, Its easyer to work with, its lighter and i want to be able to anodize it differant colours eventualy
    btw. This stuff will be running in a seperate loop which will prolly be 3/8 or 10mm or something. Ive drawn the barbs to take M8 threads but will prolly end up being bigger. I dont think it matters too much with this loop as eaven with everything in it theres less load then the cpu loop. :thumb:
  17. Thunder_return
    Thunder_return What's a Dremel?
    8 Jun 2003
    Excuse me but I cant see how you will get room for a nice
    setup in there.
    I mean, its allready crowded with stuff ( or atleast it looks like that).
    Extreme modd , keep it up!
  18. slater
    18 Apr 2003
    Well
    1. first off i will use 3/8 tubing for the 2nd loop (afterall its only for the unimportant stuff).
    2. The rad will go directly next to the one that i have allredy done
    3. I will probably swap the pump for a samller one (MCP600 would be nice)
    4. The second pump will probably go where the rear exhaust fans are
    Plenty of room! if people can fully w/c shuttles then i can do it in a cheiftec midi :thumb:
    btw. your project is looking great aswell. I will be following it
  19. Thunder_return
    8 Jun 2003
    Well, if you change some things in the w-c I get it.
    Those Chieftec midi´s looks bigger then they are :hehe:
    I hope it turns out well.
    BTW:Thanks for the comment.
  20. benje
    4 Feb 2002
    Dont mean to be nasty, but just my 2 c$nts.
    HWHAT is the point of watercooling your PSU or southbridge? I mean come one!
