Case Mod - In Progress Slaymate's Saga: Case is Finished
Discussion in 'Project Logs' started by mnpctech, 14 Feb 2009.
  1. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    agree, I love the heatpipes
    Update from the case modding dept:
    Still waiting on panels to return from powder coating. Hopefully they will be finished today!
  2. mnpctech
    21 Apr 2003
    Slaymate's A70 panels are back from powdercoating. What a Purty Gloss Black finish! Ok, Slay next on the menu is airbrushing a mural on the right panel and bezel.
  3. craigbru
    craigbru Cramming big things in small boxes since 2006
    28 Feb 2008
    That's a fantastic finish on the panels. I sometimes forget how good a quality powdercoat can look.
  4. SkyLord77
    SkyLord77 Use your teeth not a Dremel
    21 Dec 2008
    That's a gorgeous finish..... :jawdrop:
  5. Slaymate
    Slaymate bit-tech Slayer
    15 Feb 2009
    It won't be long now and I'll be ready to cruise it up and down the road at Bike Week, HeHeHe :D
    Today we will be looking at the Cooler Master 1250watt Power Supply. It was a freebie Cooler Master sent me a year or so ago and these pictures were taken then. I'd re-take them but I'm using the power supply at the moment.
  6. Slaymate
    15 Feb 2009
    I'm almost out of pictures until Bill is done.
    I recently upgraded from a 22" wide screen (in the background) to a 28" HD 1080P Monitor.
    And I bought a Blu-ray player DVD Burner Combo
    And these came in today so I'll be adjusting the V-10 tomorrow.
  7. Slaymate
    15 Feb 2009
    Well the V-10 is just a piece of crap. The different peltiers made no difference at all. I even removed the control module, as it's just an on and off switch, and ran the peltier straight off the power supply. It still made no difference. I even removed the peltier and tested it. The peltier is good for a 2 to 3 degrees Celsius reduction at best. What's even worse, for the V-10, is my temps are cooler with the V-8. I'm back to waiting for the next new cooling idea.
    Here are a couple pictures of my failed attempt.
  8. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    Air coolers and tecs always fail in performance.
  9. mnpctech
    21 Apr 2003
    Bummer..
    Lucky guy, someday I'll make it to Bike Week..
  10. SkyLord77
    21 Dec 2008
    I'm sorry to hear about your results. Major bummer. :sigh:
    On the bright side if you hadn't have attempted it you would have never known.
    It's still going to be awesome no matter how you cut it. :thumb:
    Oh yeah... At least you got the Marlboro's to keep ya company. I know they sooth my soul. :D
  11. nagyizom
    nagyizom Minimodder
    2 Jun 2008
    I'm looking forwad to see, what will you do in the next update! Very good work so far:thumb:
  12. mnpctech
    21 Apr 2003
    Thank you guys, we're excited to start painting Slaymate's mural as soon as we finish our other obligations. Slay wanted the professional added touch, I've installed black rubber u-channel and fan grommets for the 2x 120mm blow hole exhaust fans in the top panel
    fan grommets
    u-channel
    [​IMG]Heres the top panel and window panel finished.
  13. SkyLord77
    21 Dec 2008
    Looks great! I love that window Bill. :thumb:
  14. Zeroignite
    Zeroignite So I decided to simulate a Universe
    18 Jan 2009
    It's sooo..... shiny!
  15. Slaymate
    15 Feb 2009
    I've ordered a Thermalright TRUE Copper for this Mod. Big and Shiny. Expect some pic's next week :D
  16. Slaymate
    15 Feb 2009
    My new Thermalright True Copper came in yesterday :D
    I spent this morning lapping it perfectly flat with a mirrored finish :)
    And I bought a couple of these Silverstone fans that I'll be painting Copper :D
  17. tjay@TJ
    tjay@TJ Minimodder
    4 May 2008
    great cooler u have there...
  18. Slaymate
    15 Feb 2009
    I painted fans today. Here a shot of my High-Tech Paint Room :D
    I painted (2) Silverstone 120x25mm fans, (1) Scythe 120x38mm fan and (2) Fan Grills "Hammered Copper". I also painted (4) Scythe 100x25mm fans "Alumimun" and I'll be using them on my gpu coolers instead of the 100x12mm fans.
    I'm letting everything dry overnite so I'll take some close-ups tomorrow :D
  19. .Fatality.
    .Fatality. What's a Dremel?
    10 Jul 2008
    i heave the same cooler on the cpu and its awsome!
    keep it up!
  20. Slaymate
    15 Feb 2009
    Well the "Alumimun" fans for my gpu coolers turned out great. I used regular spray paint with them.
    The "Copper" fans still look good but I'll have to touch them up. The can said for Plastic, and it is suppose to have a textured look. But the paint was actually really thin and it hasn't dried good. It felt dry and just holding them was okay. But I see a fingerprint where I must of applied some pressure and the heatsink clips scratched the paint a little.
