Case Mod - Complete Sleeper G5 Water-RGB
Discussion in 'Project Logs' started by MrFlibble, 18 Nov 2019.
  1. Jangalit
    Jangalit What's a Dremel?
    28 Feb 2020
    very good! keep us informed!
    MrFlibble likes this.
  2. MrFlibble
    MrFlibble What's a Dremel?
    13 Nov 2019
    Update 5# GPU bracket and some tubes.
    First time bending tubes. Hot one bend a little hot but it is quite easy to do.
    Can't do any more work for a couple of weeks now :(
    DSC_0185.JPG DSC_0188.JPG DSC_0193.JPG DSC_0204.JPG DSC_0209.JPG DSC_0224.JPG DSC_0188.JPG DSC_0246.JPG DSC_0234.JPG DSC_0162.JPG
  3. Diletta Graziosi
    Diletta Graziosi What's a Dremel?
    27 Feb 2020
    that beast of a gpu give me anxiety on top of that tin cute mobo ahaha
  4. MrFlibble
    13 Nov 2019
    Teaser photo while I am waiting for my CNC man to get back to Australia from the US.... It could be a while.
    Temp reservoir to test everything else.
  5. Cheapskate
    13 May 2007
    :lol: You hard-lined a Gatorade bottle. I'm giving it a like for the shoelace. It adds that extra little bit of class. :D
    Yaka and MrFlibble like this.
  6. b1g-d0g
    b1g-d0g Multimodder
    30 Sep 2001
    Nice use of the case not seen one of them before.
  7. lewinernst
    lewinernst What's a Dremel?
    16 Mar 2020
    Originally started this to see if i could fit a bigger Rad than LTT into my Mac Pro case (That's a 360, but a 360*180 - it fit's perfectly to the millimeter) but i think i'm going for something more similar to you OP - here's a teaser of my upcoming Mac PrO11 Dynamic buildlog https://imgur.com/a/4DRIEcv.
    How're you progressing under quarantine? I unfortunately ran out of black carbon brass tube before getting to the gpu (as you can tell by that softtube) and don't have acces to my usual space to make a distroplate so i just used a bayres to emulate one for now.
  8. MrFlibble
    13 Nov 2019
    Hey lewinernst
    Quarantine has brought this project to a screeching halt. I need to access a CNC for my custom distro plate and that is not going to happen.
    I have spent my time Changing the 3xUSB2 ports (one front, two Back) to USB3.1. Manual soldering on to some little connectors. nickel-plated-USB-3.0-female-connector.jpg
    It will be a while I think till the last update.
    Andrew
  9. MrFlibble
    13 Nov 2019
    Update #Going Mad
    So I may have had an idea of something to do while in lockdown and then I may have bought 3 more cases.
    Was only $15 AUD ($5 each)
    Update again shortly
    lewinernst and kim like this.
  10. MADPC
    MADPC Minimodder
    10 May 2020
    I love this case, this case have no time, all aluminium...solid.
  11. MrFlibble
    13 Nov 2019
    Update 6#
    I have had to leave the original bref a little.
    1. The USB ports on the back and front will now be blue USB3 ports. Changed from the original grey of the USB 2
      I will see if I can do something to make them look more grey but I don't like my chances.
      I just needed to do this to make it usable.
      Before 2x USB3.1 and 7x USB2
      Now 5x USB3.1 4x USB2
    I was hoping that this would not happen but the PSU was heating up because it was a bit starved of air.
    I have cut 2 big 92mm holes in the bottom of the case to let the air in. They have the same grill as the back of the computer and should not really be visible.
    I think it looks good but it is not the original bref of “No external changes apart from what is in the PCI Case slots”
    DSC_0319 small.JPG DSC_0400 small.JPG DSC_0405 small.JPG DSC_0416 small.JPG DSC_0469 small.JPG DSC_0472 small.JPG DSC_0518 small.JPG
    Cheapskate and neSSa like this.
  12. MrFlibble
    13 Nov 2019
    Update 7#
    I have completely changed the way the mounting plate works. Now it’s glued onto the inner case and the outer case is screwed on last.
    It's hard to explain. I hope the pictures help.
    Basically now I can see the cables on the back of the mounting plate and there are no visible screws holding it in place.
    I am however losing a little rigidity over all as the inner case can only be screwed onto the outer case on one side.
    DSC_0202 small.JPG DSC_0206 small.JPG DSC_0211 small.JPG DSC_0224 small.JPG DSC_0487 small.JPG DSC_0519 small.JPG DSC_0520 small.JPG
  13. Cheapskate
    13 May 2007
    It always amazed me that they could make a mesh case that overheated. :lol:
    Do what you must to it. You can only improve the design.
  14. MrFlibble
    13 Nov 2019
    4 years..... Better late then never
    I just got over this not being done..
    There are to many things that didn't work. Just makes me sad to think about. Including the focus of the camera... sorry.
  15. Dot_Kappa
    Dot_Kappa 100% Puppet
    23 Mar 2006
    What about the others?
  16. MrFlibble
    13 Nov 2019
    Others?
    Other g5 cases? They are all gone to god
    jamsand likes this.
  17. Cheapskate
    13 May 2007
    4 years is nothing here. MonkeyPuzzle's Hush is on the 15 year mark.
    You need to post some proper still pics, though.
    jamsand likes this.
  18. MrFlibble
    13 Nov 2019
    hahaha.
    Ok I will take some photos.
  19. MrFlibble
    13 Nov 2019
  20. MrFlibble
    13 Nov 2019
    Also funny story. While doing the last thing I will probably even do with the silicone insert for bending the hardline, as I was pulling it out was the only time it snapped and I punched myself really hard in the side of the head / jaw. I have taken bigger hits before but I clocked myself quite well.
    Literally the last thing I did with that thing and it paid me back for all the stretching and heat I had given it.
    "Here is something to remember me by you D&^khead!"
