SLI & Crossfire motherboards?
Discussion in 'Tech Support' started by Immy, 3 Mar 2008.
  1. Immy
    Immy What's a Dremel?
    13 Nov 2003
    I want to purchase a motherboard with the X48 chipset but none of them have SLI, yet they all advertise crossfire.
    I came across a discussion on Anandtech that claims SLI works perfectly fine with Crossfire motherboards. Specifically the new Rampage Formula by Asus. Is there any truth to this has anyone tested it out and had any success?
    Does it hinder performance if you were to use 1 nvidia graphics card in a crossfire motherboard?
  2. badders
    badders Neuken in de Keuken
    4 Dec 2007
    Simple answer - No.
    Also, personally I would have stuck with one thread on the subject.
  3. naokaji
    naokaji whatever
    8 Dec 2006
    X48 chipset is a waste of money, get a x38 board if your dead set on wanting Crossfire, or a p35 board if you will have a single card only.
    as for sli, well, you will be stuck with the crappy nfarce chipsets, unless you go for Skulltrail, but then your looking at plattform prices where you can buy less than 10 year old car for...
  4. Immy
    13 Nov 2003
    I dont want to use crossfire for an ati card. I just like the x48 chipset and i'd like to know if i can use 1 nvidia card or even 2 in sli with a crossfire motherboard?
  5. badders
    4 Dec 2007
    You can use one. you can't use two.
  6. Immy
    13 Nov 2003
    thank u :)
  7. badders
    4 Dec 2007
    You're welcome. Enjoy your upgrade.
