SLI Motherboards
Discussion in 'Hardware' started by Minglemouse, 3 Jun 2006.
  1. Minglemouse
    Minglemouse What's a Dremel?
    1 Jun 2006
    What would you recommend as a good performing SLI motherboard. i currently have a Gigabyte K8NS Ultra-939 AGP 8X but i am looking to upgrade to a Motherboard with a PCI-E system as it is the way to go now.
    I would welcome any recommendations to help me decide.
  2. BUFF
    BUFF What's a Dremel?
    25 Mar 2005
    budget?
    features required?
    Abit KN8 SLI is a good board at a very reasonable price & a decent overclocker.
    If you have the budget the AN8 32X is a great board.
  3. ashikamlani
    ashikamlani What's a Dremel?
    11 Mar 2006
  4. Minglemouse
    1 Jun 2006
    ASUS A8N-SLI Premium - Socket 939 AMD - Chipset NVIDIA nForce4 SLI ATX
    this board seems to be fine but there is one probelm, and that is in a review i saw, a guy said 'Needs modern powersupply(24 pin)'. now how modern are we talking and is the 24 pin connecter standard for PSU's in this day and age?
  5. hitman012
    hitman012 Minimodder
    6 May 2005
    Well, what PSU do you have? Most higher-wattage models manufactured in the last two years will come with 24-pin ATX as standard. Note that it's not totally necessary to have a 24-pin supply, but it's recommended.
  6. Minglemouse
    1 Jun 2006
    Thermaltake Butterfly 480W.
    thanks for the help.
  7. jakeiswicked
    jakeiswicked What's a Dremel?
    17 Oct 2005
    If you actually intend to use the Sli mobo with SLi then id reccomend a newer and better PSU, if your on a budget the Hiper 580w Modular offers up to 600w or so and is rock solid stable, also quiet 18db roughly
  8. hitman012
    6 May 2005
    Yes - the ThermalTake will be fine for single-card use (should also be 24-pin), but they're not supplies that I'd trust with a dual-card configuration. If you plan to run SLI, have a look at the Seasonic 500/600W units or perhaps the Tagan EasyCon 580W.
