Graphics SLI to 680's but different brands
Discussion in 'Hardware' started by Kovoet, 9 Apr 2013.
  1. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    Guys is it possible to sli two 680's but different brands as in Asus DCll and a PNY
  2. Parge
    16 Jul 2010
    Yep! :thumb:
  3. Teelzebub
    27 Nov 2009
    So long as they are the same model and spec there shouldn't be any problem
    Apophis54 likes this.
  4. Kovoet
    26 Aug 2009
    Yep both 680's
  5. Elton
    23 Jan 2009
    You'll be fine. It'll just clock itself down to the slowest card though.
  6. Kovoet
    26 Aug 2009
    Thanks guys right think its time to try sli. Crossfire was real easy to setup
  7. Guest-44432
    Guest-44432 Guest
    Not true. They will run at their default overboost clocks. Just make sure the power targets are the same on each card, otherwise you will be in the hole I was in fightimg with drivers.
    So check in MSI sfterburner what your max power target is on each card. I.E 145%
    If they are the same, then you shouldn't have any problems. ;)
  8. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    As long as they have the sameish clocks and same memory size, it is fine. When mixing brands I always used to just take the lazy way and flash both with the same bios.
  9. sandys
    sandys Multimodder
    26 Mar 2006
    flash em both with the same bios, job done.
  10. Elton
    23 Jan 2009
    Oh right! For an inexplicable reason I read 580s.
    Hey TrueGamer, when you get rid of your 670s, want to send one over my way? I kinda want SLI. :D
  11. Guest-44432
    Guest-44432 Guest
    I tried that on the SC card, and it made no differences... Still had problems. Could be down to having less Capacitors/Phases perhaps.
    I don't plan on upgrading for a yr or two on the GPU's. Unless the GTX 780's leaves the Titan in the dust. :)
  12. Elton
    23 Jan 2009
    It's all good, I'm just looking for a rather cheap GTX670 Cheesecake as I have one already.
    Who knows, Tri SLI? ;)
