Cooling Slight water loss
Discussion in 'Hardware' started by Mighty Yoshimi, 26 May 2007.
  1. Mighty Yoshimi
    Mighty Yoshimi Motormouth
    4 Sep 2006
    I have watercooling blocks 2 G71, Lga 755 and NB chip watercooling and i have a cape coolplex resivoir and its water level has decreased but there doesnt seem to be a leak, is it possible that the tygon tubes have swollen slightly? To account for the misplacement
  2. pdf27
    pdf27 What's a Dremel?
    6 Jul 2006
    Tygon tubing is slightly porous - so you will over time lose a small amount of water without leaks.
  3. Mighty Yoshimi
    4 Sep 2006
    Ahh kl thanks if i had to guess its lost about 4 cm height in a 5 cm diameter tube, so 4 * (3.1415*(2.5)^2) ml of water
  4. Krikkit
    21 Jan 2003
    That seems like a lot of water to be losing - it should be ~1cm/year max in that res tbh. Be wary of a slow leak somewhere...
  5. Mighty Yoshimi
    4 Sep 2006
    i meant ml obv lol, over 8 months so about 70 + ml in 8 months, im not aware of a leak anywhere though it would need to be very marginal
