I've been looking at 140mm fans, and in the scythe section there are two 800rpm fans, however one is different and is showing the 1700rpm details, is this just a typo, as i don't want to order and get the 800rpm instead of 1700 rpm. Link, http://www.aquatuning.co.uk/product...40-mm-Case-Fan---800rpm---140x140x25mm--.html Thanks
Hi, yes it will be a typo - will get it fixed. you can check the Model number on the scythe website for exact details while i sort it
