Networks slow connection....
Discussion in 'Hardware' started by Black-Ice, 9 Aug 2002.
  1. Black-Ice
    Black-Ice What's a Dremel?
    2 Jul 2002
    Ok i routed my 2 computers on a 4port BELKIN DSL/Cabel router. I have a DSL line and i get a DL rate equal to a 56k on this computer!!! on the other computer the DL rate is how it should be. Why is mine much slower? Plz help
    Black-Ice
  2. Shadowspawn
    Shadowspawn Another hated American.
    1 Jul 2002
    Thats a bit odd...
    Were you downloading something on the computer with the normal rate when you checked the rate of the other computer? Did that make sense?
  3. Black-Ice
    2 Jul 2002
    no the computer that has the good rate is on idle right now doing nothing but being connected to the internet. This computer i am on now is slow as ****.
    Black-Ice
  4. Shadowspawn
    1 Jul 2002
    Are the two computers identical? What are their differences?
  5. ChriX
    ChriX ^
    30 Aug 2001
    I suggest swapping the ports over so that the currently slow connected pc is in the fast ones port on the router, if that makes a difference it could be a dodgy port on the router. If not it could be the cable connecting the slow pc, the NIC or possibly the settings on the computer :eyebrow:
  6. Black-Ice
    2 Jul 2002
    yea i think i may be using the good cabel to connect the fast pc...so i'll try swaping them..thanks
    Black-Ice
  7. ChriX
    ChriX ^
    30 Aug 2001
    Let me know how it goes
  8. Black-Ice
    2 Jul 2002
    i did that and its still as slow:cries:
    Black-Ice
  9. VadimtheConqueror
    VadimtheConqueror I love the little tacos...
    10 Jul 2002
    i'm having the exact same problem, just started today.
    i'm using the good cable on this computer, and the other one is a k6-233 with a 10base t nic, yet it's going faster
  10. ChriX
    ChriX ^
    30 Aug 2001
    That is really strange I cant think of anything else to suggest :eyebrow:
  11. VadimtheConqueror
    10 Jul 2002
    black-ice, does it happen to you occasionally then go away for a few days, or is it consistant?
  12. Black-Ice
    2 Jul 2002
    its consistant...i get a dl rate of like 10kbs/sec but thats only for like 1min...never really happens. But when i play CS i get an OK PING
    Black-Ice
