Modding Slow day at work (make a T-Rex)
Discussion in 'Modding' started by M_D_K, 11 Apr 2013.
  1. M_D_K
    M_D_K Minimodder
    3 Apr 2002
    Wasn't sure what section this should go in,
    Always wanted to try one of these and we're a bit quiet so got a T-rex cut out and just need to Tack it together and get Acid Blacked or possibly nickel plated not decided yet.
    6mm Thick CR4 Steel.
    Untitled by Kiteninja (Morgan Lee), on Flickr
    I found the plans online along with some others and plan to make another T-Rex twice as big :) and also some other creatures :D
    Anyone want one ?
    Morgan.
    Tangster likes this.
  2. Tangster
    23 May 2009
    That is awesome. I'd love one, but I don't think I'd have anywhere to put it. :(
  3. alpaca
    alpaca llama eats dremel
    27 Jan 2009
    That's beautiful. What does it weigh? (and how much do you want for one?)
    I made something similar but in MDF. I wonder how the pterodactyl would fare in steel...
  4. M_D_K
    M_D_K Minimodder
    3 Apr 2002
    Thank you, I am very impressed with how its looking so far, I'll work out some costs if more people want in, I'm not sure on the exact weight but it is pretty heavy I would say around 20kGs at a rough guess.
    The Pterodactyl would weight a ton at that scale I don't think you would want it from your ceiling but I'll look at scaling it down and see what it comes out at :).
  5. theshadow2001
    3 May 2012
    When I was a kid, I collected a bunch of dinosaur magazines which gave you a part each week to make a plastic skeleton that looks almost exactly like what you have made there.
  6. M_D_K
    M_D_K Minimodder
    3 Apr 2002
    I had the same thing :) was yours the glow in the dark one and at the end you could get the skin that clipped on :)
  7. Lance
    Lance Ender of discussions.
    6 May 2010
    Yup I had that all the way in New Zealand.
    I would also potentially be interested in this. Especially if its still deconstruct-able.
  8. theshadow2001
    3 May 2012
    yeah thats the one
  9. The_Crapman
    The_Crapman Don't phone it's just for fun. Staff
    5 Dec 2011
    That's amazing. It looks like my mate tony.
  10. M_D_K
    M_D_K Minimodder
    3 Apr 2002
    Only if you don't weld it together, it does stay pretty well together the only issue is the tail & spine pieces due to the weight of the head they slide apart everything else is fine I guess I could try and fit a small clip to keep them together.
  11. bigc90210
    bigc90210 Teh C
    7 Oct 2003
    I still have both at my parents, and i painted the skin, and all the mags from start to finish :D
  12. Atomic
    Atomic Gerwaff
    6 May 2002
    Could you cut it out of alu to cut down on the weight?
  13. Lance
    6 May 2010
    Are you going to make the skin as well then? :dremel:
  14. M_D_K
    M_D_K Minimodder
    3 Apr 2002
    Yes but then the price of material will double, did it out of steel because its cheap & it lasers the cleanest, ali does cut really clean but it still needs some finishing where as steel comes straight off the laser burr free & looking shiny.
    I'll weigh it on Monday when its all welded and assembled.
    I wont be making a skin lol maybe if I had a really big 3D printing that could be possible :).
  15. Cheapskate
    13 May 2007
    Awesomeness made only awesomer by the fact that it can be used as a weapon.
  16. kenco_uk
    28 Nov 2003
  17. M_D_K
    M_D_K Minimodder
    3 Apr 2002
  18. faugusztin
    11 Aug 2008
  19. M_D_K
    M_D_K Minimodder
    3 Apr 2002
  20. M_D_K
    M_D_K Minimodder
    3 Apr 2002
