Storage Slow to revive from sleep
Discussion in 'Hardware' started by CrapBag, 19 Jun 2014.
  1. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    I recently reinstalled win 7 on my pc as it had been a long time since I'd last done it.
    One of the reasons for doing it was that benches on my 840 evo were below what they should have been and once I had completed the reinstall they were back where they should be,
    The only thing is when I bring the pc out of sleep, once I see the desktop I can't do anything for up to 10 seconds, the mouse pointer moves and if I click on anything nothing happens, well I say nothing, whatever I click on happens but only after about 10 secs when the system becomes responsive.
    Is it worth reinstalling as I never had this issue before, one thing worth mentioning is I did update the firmware to the latest before I reinstalled.
  2. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    Did you update the disk controller/chipset driver? I had such problems on a system until I installed the proper intel drivers... the MS generic ones included on OS are sometimes odd this way I find.
  3. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    Yeh I did this.
    I must admit I hadn't done so in the past though.
    I will scan again though and make sure all is well.
  4. IvanIvanovich
    31 Aug 2008
    Are you 100% it's resuming from sleep and not hibernation? Try disable with " powercfg -h off " from admin cmd, reboot and check it again.
  5. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    Nope didn't fix it.
  6. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    RST service takes an age to start running if that makes any difference.
  7. RedFlames
    23 Apr 2009
    Do you have any mechanical drives in the PC? My PC can be a bit slow to wake [but still not 10 seconds slow iirc], and most of that is waiting for the HDDs to spin up...
  8. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    Yes I have one hdd but I can't see it being that as the OS is on the SSD and it wasn't doing it before the reinstall.
