Electronics Small Homemade PSU ?
Discussion in 'Modding' started by emj1s, 4 Nov 2004.
  1. emj1s
    emj1s What's a Dremel?
    26 Jun 2004
    How can i take 120v AC and turn it into 5v DC. I have the transformer, part # 273-1385-radioshack) and i need to know what else to get and how to assemble it without killing myself. :worried:
    Any help is appreciated. emj1s
  2. cpemma
    cpemma Ecky thump
    27 Nov 2001
    You'll need a bridge rectifier, 1A 50V will do, say Catalog #: 276-1173, a smoothing capacitor around 1000uF 35V or more, say Catalog #: 272-1032 and a 7805 voltage regulator with an output capacitor such as the 10uF tantalum Catalog #: 272-1436, or a couple of cheap ceramic 100n-220n would do, one either side of the regulator.
    At maximum load the regulator will be losing over 3W so it will need a heatsink like Catalog #: 276-1368 if you're going over 100mA.
  3. emj1s
    26 Jun 2004
    are those radioshack #'s and how do i assemble it, i have no idea at all, except i want to plug it into a wall and have 5v coming out.
  4. sinizterguy
    sinizterguy Dark & Sinizter
    25 Jul 2002
    If you are asking how to assemble it, you might be better off buying a ready-made adapter IMO. Not meant as an insult, but no one here would want you to electrocute yourself.
  5. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Looking at those RS prices it will probably work out a lot cheaper too. Look for a regulated adaptor, or just build the 5V regulator side (2 small capacitors and a 7805) and use a basic 9-12V wallwart, you must have a few old ones round the house.
    Whole thing looks a bit like this:
  6. emj1s
    26 Jun 2004
    ok, um, lol, siniz your probly right this time round. can anyone point to a kit or asembled psu that plugs into the wall, about 120v, and pulls down to 5 to 12v out.
  7. emj1s
    26 Jun 2004
    Whats a wallwart
  8. Herbicide
    Herbicide Lurktacular
    27 May 2004
    This is a wallwart...
    It's basically an adapter either built into, or in line with a plug.
    - H.
  9. theshadow27
    theshadow27 What's a Dremel?
    23 Sep 2004
    just go to radioshack and ask for a 6volt power adapter, they will hand you one that can source about an amp and costs about 10$ american. thats all you need to do
    http://www.radioshack.com/product.a...name=CTLG_009_001_001_001&product_id=273-1761
    (Catalog #: 273-1761) for example
    then get a diode and put it inline with the circut, it will drop it down to 5.4v
    or you can buy a 4.5 v adapter... it all depends on what your doing
  10. zz300
    zz300 What's a Dremel?
    7 Mar 2002
    I f you're not too concerned with looks (or are going to hack it up anyway): these guys have some good deals.
  11. emj1s
    26 Jun 2004
    thanks for all of yalls help. im just gonna chop a walwart up and mod to my needs, thanks.
