Notebooks Small Laptop for my 11 year old son
Discussion in 'Hardware' started by Pontius Pilot, 24 Oct 2010.
  1. Pontius Pilot
    Pontius Pilot What's a Dremel?
    29 May 2010
    Hi folks,
    Just need a bit of buying advice please on buying a small laptop/larger notebook for my son.
    He has dyslexia and it has been recommended he uses this voice recognition software to be able to write longer homeworks (http://www.nuance.co.uk/naturallyspeaking/products/premium.asp).
    I've tried it on my laptop and it works really well but a full size laptop like mine is way too heavy for him to carry around all day.
    So I am looking for something light but larger than the average notebook as they are too small I think for him. Good battery life and as durable as possible (he's 11 so will probably be smashing it into everything!!). Also it need to run windows 7. He'll also be using it for web browsing, iplayer and have some music on it too.
    Any thoughts or help would be very much appreciated. :D
  2. murraynt
    murraynt Modder
    6 Jun 2009
    I think you should be looking at one the the CLUV powered notebooks.
    Im using one as i write this.
  3. Pontius Pilot
    29 May 2010
    Thanks for the reply, what is the brand? are they expensive?
  4. shadow19935
    shadow19935 Whats overclocking? :D
    17 May 2010
    Not sure tbh, try some from the acer line?
  5. Oggyb
    Oggyb Mutant
    15 Jun 2010
    Be warned, I have friends who had Acers that fell apart after 6 months. If your son is boisterous with his belongings you might want to consider something else.
    Check Engadget for "thin and light laptop for carrying around" type laptops such as this:
    http://www.engadget.com/2009/12/15/msi-slides-out-13-4-inch-x-slim-x350-culv-laptop/
    I used "culv" as the search term.
    Lenovo would be another recommendation:
    http://shop.lenovo.com/SEUILibrary/...=05396D3B778B4C93BFDA918C8E4815E2&action=init
    I had a Dell but it only lasted 18 months. Might be different nowadays. What is your budget?
  6. docodine
    docodine killed a guy once
    10 Feb 2007
    Dell Vostro V13, Asus UL series, Acer Timeline, MacBook Air
    Though IMO it would be far more beneficial for the child to learn how to write correctly than to depend on dictation..
  7. Bungletron
    Bungletron Minimodder
    25 May 2010
  8. Siberdine
    Siberdine Safety Not Guaranteed.
    1 Aug 2010
    A budget would help us narrow your search down, but also, how big is big? 14" screen? Larger? Most CULV laptops I can think of use 13.3" screens, or something along those lines. Off the top of my head, Asus UL20 or UL30 are pretty good, but the screen might be too small for your son, and it's pretty expensive (£400-450). If that's too small, look at the Asus UX50V. It's light, stylish (not that stylish matters), a 7 hour battery life while running a word editing program, has a graphics card using nVidia Optimus , and a pretty comfortable keyboard. The two downsides are that it's £700, which is a lot, and the performance isn't very quick for such a costly computer.
  9. Pontius Pilot
    29 May 2010
    Hi thanks for the replies so far, budget is max £450 preferably less. I looked os a website and found this, is it one of the ones? Price seems ok??
    http://www.asuslaptop.co.uk/proddetail.php?prod=UL30A-QX131V
    Please keep the ideas coming I need to get something in the next few days!!
    Thanks guys...
  10. Pontius Pilot
    29 May 2010
    Also I think the 13.3" would be perfect in terms of mobility.....
