Storage Small RAID boards for a semi-mobile NAS
Discussion in 'Hardware' started by OtakuHawk, 12 Feb 2010.
  1. OtakuHawk
    OtakuHawk What's a Dremel?
    30 Apr 2003
    Greetings BT,
    I was doing another one of my hare-brained project ideas, and was wondering what was out there in terms of nano-itx or similar sized boards.
    A: I need 4x sata ports with raid, or at least PCI/PCI-e expansion so I can stick a raid card on there.
    B: gigabit LAN
    this is a really small NAS build. anyone seen anything similar to my requirements out there?
  2. bigkingfun
    bigkingfun Tinkering addict
    27 Jul 2008
    I cannot seem to find a nano-itx board with gigabit lan.
    The most powerfull nano-ITX I did find was a 1.5 GHz VIA here. It does have a mini-PCI expansion slot, but I think your SATA RAID capabilities is limited on that.
    If you want something more exotic, Kontron makes some dual-core intel based boards.
    They have two C2D versions matching your specs. Linky1 Linky2 I have no idea how to power them though, and I think a ITX board would be cheaper.
    If you want to go the ITX way, Zotac have several that fits your criterias:
    Atom based with 3 SATA ports.
    Socket 775 based with 5 SATA ports.
    Socket 1156 based with 6 SATA ports.
    They all have a PCIe 16x explansion slot as well.
    Happy hunting!
  3. bigkingfun
    27 Jul 2008
    I came across CompuLab.
    They might have something you could use.
