Planning Small Sleek Minimal Water Cooling Design
Discussion in 'Modding' started by ianclowe4c, 26 Mar 2011.
  1. ianclowe4c
    ianclowe4c What's a Dremel?
    17 Jul 2004
    Hello out there. This is the first time I have truly posted anything on this website besides comments to others. I am looking into planning my next build. I am wanting it to be water-cooled, sleek, minimal and black aluminum for sure. I am torn between using a micro atx or an atx motherboard mainly because i am not sure if the MSI X58M motherboard is sufficient for a micro atx gaming build. I am torn between several cases and am also open to others out there as well. Please help me decide on what case to use. I am looking at cooling an i7 and two video cards all on one loop. I know i can do it on a 240 rad but wouldn't it be better to use a bigger one. Listed below are the cases i am considering. Please help and give me constructive criticism as to which one to get with considering how much i need to cool. I do think i will be starting with only one video card to start with though.
    Silverstone FT-03
    Silverstone FT-04
    Lian-LI PC-V354B
    LIAN LI PC-A04B
    Corsair Obsidian Series 650D
    Please also keep in mind that i wanting to keep a black and blue theme for this mod so i am wanting to get a motherboard that can accompany that (MSI X58M).
    I appreciate any help that can be provided. This will also be my first water-cooling project so any other help would be highly appreciated.
    Regards,
    ianclowe4c (Ian)
  2. cchr
    cchr Minimodder
    24 Nov 2010
    Silverstone FT04?!? That model does not exist, must be a typo i guess right?
    From the cases you've got there, i think that although ft03 is the best looking one, it doesn't provide as much space inside as i would personally like. i'd go for the corsair 650D, but maybe you should also check out the 600T, i know its not fully aluminum but it's also a good choice imo.
  3. ianclowe4c
    17 Jul 2004
    You are corrent. I meant the FT02
    I have narrowed it down to the FT03, V354B and the Obsidan 650D. Please help me chose the best one. I appreciate it guys out there.
  4. Paradox42
    Paradox42 What's a Dremel?
    15 Oct 2010
    I would go with the 650d
