Modding Small Sunday mod (Painted laptop)
Discussion in 'Modding' started by Smilodon, 14 Oct 2007.
  1. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    After a week vacation i have some schoolwork waiting to be done. I figured this was a good time to be creative. (Anything to avoid doing what I'm supposed to do, right.)
    I figured I'd mod the latest addition to my "family", Lore. (All my computers are named after the gods in the Zelda series)
    This one will be dragon themed.
    Here is the template for the painting printed on adhesive paper and cut with a paper knife:
    Said template glued on the lid of the computer...
    ...add some paint...
    And volá; a dragon!
    taking some decent pictures was a pain, since the surface is semi reflective, and i just couldn't get a light source in right place. The lid is dark gray metallic (original paint), and the dragon is silver metallic. (Not white, as it might seem like in the pictures) The edges also seem a bit rough on the pictures, but they are pretty smooth in real life.
    So, not much of a mod, but it was a nice thing to do on a Sunday afternoon.
  2. atanum141
    22 Jul 2004
    Nice quick and easy mod, just a question but where did you get the stencil/template?
  3. gnidnu
    gnidnu Beware of the Tofu!
    9 May 2006
    Looks really good. What kind of colour did you use? Don't you worry about wearing off?
  4. Smilodon
    25 Mar 2003
    From my printer... ;) the image is just some random picture from google.
    The paint is some standard spray paint. (CRC Pro paint, IIRC). I don't think wear will be a problem. And if it does, i have more paint :)
  5. Hazardous
    Hazardous What's a Dremel?
    21 Jan 2004
    You could always give it a coat of lacquer, instead :idea:
  6. Ryu_ookami
    Ryu_ookami I write therefore I suffer.
    11 Mar 2004
    cover the paint in hairspray acts like a quick lacquer (it works for my warhammer Tomb Kings)
  7. Smilodon
    25 Mar 2003
    hairspray? Isn't that pretty sticky? (and water soluble?)
  8. Ryu_ookami
    11 Mar 2004
    nope not once its dried it isn't
  9. Duste
    Duste Sierra my delta, bravo!
    1 Oct 2006
    Heh, that's pretty cool. :D
  10. Colossous
    Colossous Minimodder
    28 May 2007
    Sweet mod dude ! :D
  11. tranc3
    tranc3 ADHD Modder
    16 Jul 2007
    looks pretty sweet, considering its a google image and rattle can, actually look really good. good job mann!. i need to re do my "Matt-top" soon, it's in dire need of better paint, sanding. it deserves another face lift.
    ((i like how you name all your computers after the Zelda gods thats creative)
