evga GTX 260 SSC RMA'd, GTX 470 due back in the post. Worth trying to get another one for SLI would you reckon? X58 rig btw.
1920 x 1200. It was only a back up card anyway, currently using GTX 275, the one with the extra GDDR3 - 1792MB.
I'd try to see how much I can get for the card and just sell it. Those things are so damn hot and loud I just didn't want to use mine! But gratz anyway, it's always nice when warranty really works in your favor.
That bad? Got to be a step up from the 275 though -dx11? I hate loud hot cards too I must admit. I might have a go at modifying the artic gtx accellero I had on the 260. Or try & fit the msi twin turbo cooler off my 275 possibly? Sent from Bittech Android app
Performance-wise, sure, it's going to destroy that GTX275, but for me the noise and heat was just too much. Personally I switched to using a Gainward GTX 560Ti Phantom, which offered roughly the same performance at 70+ watts lower power consumption.
