As per the title please, I have just got all excited about Elite Dangerous and might fancy swapping the last Dell 3008 on my desk for 3x slim bezel 1080p panels. If I were to do this, what panels might people suggest I go for? Simply put I am after cheap good panels that have super duper thin bezels. I have got 2 DVID, 1 HDMI and 1DP output on my gphx card. Iain
Well in an ideal world the distance from the edge of the panel (physical) to the first and last column of pixels would be ... 0mm ;-)
So then U2414H is the thinnest consumer grade monitor you can get. Else then that, you need to get the displays found on video walls, which you can't. You need to contact the manufacture, such as LG, to order it, and they''ll come and install it, as they are fragile and knocks on the side with shader the glass. Transportation of such display is also an issue. You need to call for a quote on pricing (display(s) + installation).
If you have the space, why use monitors at all? https://forums.robertsspaceindustries.com/discussion/133315/my-initial-ac-cockpit
