Modding Smallest fully working PC competition
Discussion in 'Modding' started by madhatter, 21 Oct 2003.
  1. Stanmanfoo
    Stanmanfoo What's a Dremel?
    14 Sep 2003
    I'm starting to build a mini-LAN PC from an electric guitar amplifier, using a Biostar M7NCD. It's got dimensions of 305mm by 199 mm. Not the world's smallest, but it is certainly smaller than ATX.
    Here's a link to the board, if you care to check it out...
    Biostar
    When I start in on the project, I'll most likely make a project log. be on the lookout for it.
    Stan
  2. Shwang
    Shwang What's a Dremel?
    4 Jul 2003
    There are some SFFs smaller than mini-ITX. Smallest I know of that haas been used to work as a PC has been a 3.5" mobo with cpu and memory, with a memorystick as the HDD. Can't find a link, but hopefully some people know of them. The one I saw was modded into a PSU.
    Here's the linky. Linky
    Can't find the manufacturer.
  3. igotid24
    igotid24 What's a Dremel?
    19 Oct 2003
    there was another thread about this that I posted this in, but here it is again: Techsol Medallion
    As I said in the previous post its being used in a robot that I am designing an arm for. Its not really meant to be a pc, but if you really wanted to you could.
  4. HAXOR
    HAXOR Minimodder
    14 Oct 2003
    I actually had this computer for some time, but it was just collecting space and dust, so I sold it:
    It was a computer called "Modular" and was a 486SX 20MHz. It was 1/3 of the size of a shoebox, and had PS/2 for keyboard and mouse, parallel port, serial, external floppy port, and a few other things. I used two 72-pin SIMMs, and a laptop harddrive up to 2GIGs, and a minimum of 780MB. It was functional, but since I never had a hard drive for floppy drive for it, I could never get past the post. Twas a fun little machine none-the-less. I hear from a friend that a library in Canada uses them for everything. I have never seen or read about it or anything like it though, so good luck on pictures ;).
  5. MarcelloRupelli
    MarcelloRupelli What's a Dremel?
    30 Jul 2003
  6. kisa_444
    kisa_444 What's a Dremel?
    15 Oct 2003
