Cases Smallest possible full ATX case?
Discussion in 'Hardware' started by bennylava, 22 Dec 2020.
  1. bennylava
    bennylava What's a Dremel?
    18 Nov 2020
    Hi all, I'm looking to turn my current gaming rig into my office computer. So I want to save some space by putting everything into a much smaller case. The full tower isn't necessary anymore. So I was hoping someone here knew what the smallest full ATX case is these days. My motherboard is a Gigabyte z77x-UD3H, so it's dimensions are 30.5cm x 24.4cm. I think that might be the limiting factor.
    So I'm just looking for the lowest volume case I can possibly buy that will fit that board. I figured this would probably be a good place to ask. Thanks!
  2. enbydee
    enbydee Minimodder
    10 Jul 2014
    The Raijintek Thetis is pretty dinky.
    You motherboard is standard ATX size, 12 x 9.6 inches.
    Arboreal, David and Bloody_Pete like this.
  3. bennylava
    18 Nov 2020
    Thank you, I'd never heard of that case. I'll put it on the list. Is that the smallest one in volume? I want to see just how small I can go. I'll be working with limited office space so the smaller the better.
  4. David
    7 Apr 2009
    < 28 litres? Jeez, I've seen bigger ITX cases!
  5. enbydee
    enbydee Minimodder
    10 Jul 2014
    I think it's getting there, much smaller and you have to compromise other things e.g. won't fit an ATX PSU, or a discrete GPU, or a non-slimline CPU cooler, or any HDDs... etc. The Thetis is 5.5cm taller and 12cm wider (or deeper depending on how you look at it) than the motherboard so there isn't much more space to be deleted; here's some pictures https://semiaccurate.com/2017/09/28/raijinteks-thetis-window-case-review/
  6. Vault-Tec
    30 Aug 2015
    You need an SFXL PSU, mind.
  7. Arboreal
    21 Jan 2011
    The Sliger built Cerberus X at ~22L is about the smallest conventional ATX case out there, albeit at a cost.
    Some of the SFF guys have created 10L or so ATX cases, but they are pretty compromised in terms of what you can put in them. e.g. GPU on flexi riser and mounted parallel to the board, obscuring the rest of the PCIe slots.
  8. Sgoaty
    Sgoaty Minimodder
    4 Feb 2005
    You mention gaming rig. What GPU are you using? That may also be a limiting factor
  9. bennylava
    18 Nov 2020
    Likely something very small, like a Gt 1030 or amd equivalent. I'll probably sell the GTX 970 that's in it now, and replace it with the smallest card that can easily handle 1440p streaming video. As I often reference youtube for work. In this way I save money, cause while an i5-3570k rig is a lower end gaming rig these days, it's a wonderful office computer, especially since I use Linux which takes up less resources than windows.
    So I just need to identify the smallest case, and weigh that vs building one that's semi-open air. Once I finish researching whether or not that can become a fire hazard. Doesn't seem like it would be, but I'm sure they build cases for a reason.
  10. Arboreal
    21 Jan 2011
