you guys have any ideas what kind of pump i could use in a shuttle?? it would be great if you could tell me what the smallest pump avaliable is? Matt
Look at the CSP750 by C-Systems (if you don't like the blue, it is also sold in black by D-Tek Customs). Else Swiftech is about to bring out a new small pump made by Laing, the Delphi DC pump.
In addition MaxiJet 900s are not bad and are v.small. The 1200 versions are ok but run a little hot for inline use (IMO)
hey man check this out http://www.wizdforums.co.uk/showthread.php?t=400 this is just so domn cool. i want 1 (incase the pump fairy is listening) or better still 2!
That's showing the compacttube for a Ehiem Compact 600. If you want realy small then you want the adaptor for the 300 click for pic from http://www.aquacomputer.de only EUR17 for pump and and adaptor!
blimey they are small!!! well i think the temptation to water cool my shuttle is more tempting every second, and now i know how small the pumps are, i think i might make the plunge (like the pun ) and give it a wirl!
www.wizd.co.uk if you want them in the UK. I don't beleive Pug will automatically have stock, but he should be able to get them in for you.
