Other Smelly joystick
Discussion in 'General' started by Pete J, 25 Mar 2015.
  1. Pete J
    Pete J Employed scum
    28 Sep 2009
    Bit of a weird one, which I debated putting under hardware...
    I recently purchased a Logitech wireless joystick off the old eBay. The controller works absolutely fine but has a very strong aroma of what can only be described as 'fat geek smell'. I've tried wiping it thoroughly with isopropyl alcohol which has only marginally helped.
    Has anyone got any advice?
  2. Falco2073
    Falco2073 Minimodder
    17 Jul 2011
    I'd imagine vinegar would do the trick, though I probably would have initially recommended isopropyl and that didn't work, so maybe vinegar wouldn't either.
    The only other thing I can think of would be to just leave it in the sun for a bit, though I'm not sure how kindly the plastic would take to that.
  3. ferret141
    ferret141 Minimodder
    18 Oct 2010
    -IP has already been mentioned.
    -Vinny too.
    -Sun.
    -Few drops of bleach in water and wipe down. Test it on an inconspicuous corner in case the plastics don't like it.
    -If you're comfortable opening it up then do so and wipe the joints and seams.
    How old is it? I'm thinking it could be the plastic itself or the rubber grips (if it has any) could be degrading in some way and giving off that smell.
  4. Teelzebub
    27 Nov 2009
    Nose plugs would work :thumb:
    GaryP likes this.
  5. Margo Baggins
    Margo Baggins I'm good at Soldering Super Moderator
    28 May 2010
    Stick it in a box with a big dish of bicarb, leave it for a few days - is quite good at removing smells from stuff.
  6. Scroome
    Scroome Minimodder
    26 Apr 2011
    Nuke it from orbit.........it's the only way to be sure.
    Sorry, I couldn't resist
  7. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    Adds to the value surely!
  8. MeddlE
    MeddlE Norwegian Blue
    23 May 2011
    I came to this thread expecting a personal hygiene question.
  9. David
    7 Apr 2009
    :hehe:
  10. Shirty
    18 Apr 1982
    I came here expecting to see the results of a drunken one night stand with a flight sim. I'm only slightly disappointed.
    Grab some Milton fluid rather than bleach, it will sterilise the surfaces it touches in 15 minutes and won't hurt either hard or soft plastics.
  11. GaryP
    GaryP RIP Tel
    31 Aug 2009
    For the record I have never owned a Logitech Joystick despite the qualifying conditions.
  12. Behemoth
    Behemoth Timelord in training
    1 Nov 2001
    Kick it it in he ovaries, and fill it with mustard . . . .oh wait it's a Joystick lol.
    Just could be the age of it like others have said, I've bought things used that have been a bit smelly but never as bad as stated in first post.
  13. Mister_Tad
    27 Dec 2002
    Before you use it, just think of all the things that the smell may be. All of the things "fat geek" may have had his hands on prior to, and even during use of the joystick.
    Sure, you may be able to wipe off some of the residue and even mask the smell, but you'll always know where it's been.
    Always.
  14. Shirty
    18 Apr 1982
  15. MeddlE
    23 May 2011
    Is he 'using' the joystick?
  16. Sanzy
    Sanzy Minimodder
    27 Nov 2005
    burn it with fire!
  17. Shirty
    18 Apr 1982
    I'll leave that to the imagination :(
  18. Nexxo
    23 Oct 2001
    Epic thread is epic. :lol:
  19. LennyRhys
    LennyRhys Oink!
    16 May 2011
    Logitech wireless joydick? This one? Second hand...?
  20. lilgoth89
    lilgoth89 Captin Calliope
    12 Mar 2011
    dettol antibacterial is pretty nifty for removing smells ( or mearly overpowering them )
    if you can get it apart ( you may need to remove abit of man-glue ) then just soak the case in Dettol for 24 hours before COMPLETELY washing it ( that stuff is irritant on the skin )
