Modding Smoking Plexi-glas ??
Discussion in 'Modding' started by Linkitch, 31 Jul 2002.
  1. Linkitch
    Linkitch What's a Dremel?
    11 May 2002
    Im currently working on a Glow-Pad Final Edition.
    And i want too smoke some of the Plexi-glas... but how do i do that ?
  2. eddie_dane
    eddie_dane Used to mod pc's now I mod houses
    31 Jan 2002
    The only way I know of to "smoke" plexy that is clear (assuming you don't have the option to order smoked plexi from a supplier) is to use automotive window tinting... got some from local autoparts and it was easy enough to apply...
  3. inder
    inder Mr.Modtown
    17 Jul 2002
    a light sanding would also produce a similar effect, but a spray tinting would give a better result
  4. mc909
    mc909 What's a Dremel?
    18 Jul 2002
    just don't inhale....
  5. linear
    linear Minimodder
    5 Oct 2001
    hehe beat me to it. :D
  6. inder
    inder Mr.Modtown
    17 Jul 2002
    unless you want to try the new 'bodymods' - spray your insides using frosting, allows light to give nice glow and gives a nice effect, which can be seen thru the plexi sealed hole in your stomach
  7. fathazza
    fathazza Freed on Probation
    20 May 2002
    in the uk there is a brand called plastikote... there glass frosting spaycan is really good for perspex.
    availible at most harware shops in the uk (b&Q for sure) but i guess that doesnt help u in denmark ;)
  8. Seth
    Seth What's a Dremel?
    14 Mar 2002
    on a comical side you shouldn't smoke plexi-glas it is not good for you.
    kinda like drugs heh
  9. funy
    funy What's a Dremel?
    23 Oct 2001
    *under breath* "you wanna buy an ounce of plexi??"
    :D lol
  10. inder
    inder Mr.Modtown
    17 Jul 2002
    haha, btw funy you trying to tell us something?
    irc.hashnet.org :eyebrow:
    :D
  11. Linkitch
    11 May 2002
    Thx for all the responses...
    I'll get on with the modding then... :D
  12. fathazza
    20 May 2002
    my problem is not wiht smoking plexi.... but with ****ing cutting the damn stuff in a straight line.
    the only theing i have for cutting is a fifteen quid dremel clone and i seem to like cutting in nice wavy lines....
    doh
    project thundercat continues....
    hazza
