Networks Smoothwall Express
Discussion in 'Hardware' started by lcdguy, 27 Jul 2007.
  1. lcdguy
    lcdguy Minimodder
    25 May 2004
    I basically wanted to know if implementing something like smooth wall would be more secure then my current solution or should i just stick with what i have.
    Currently i use a Netgear Prosafe VPN Firewall. What i really want is the added service and network traffic monitoring it seems to have.
    Or is there something better like OP Manager or Cacti/Zabbix
  2. RTT
    RTT #parp
    12 Mar 2001
    IPCop > Smoothwall in my experience, and i'd probably place either of those as being "better" than your netgear thing :)
  3. wsurritte
    wsurritte What's a Dremel?
    31 Oct 2005
    I like Brazilfw Firewall and Router better than either one. Far less resources, and faster web admin and standard ssh.
    http://www.brazilfw.com.br
  4. lcdguy
    lcdguy Minimodder
    25 May 2004
    i am now running ipcop :D. i would have preferred smoothwall 3.0 since it has alot more features but it won't see my pcmcia nic so i have to use ipcop. so far i like it. especially the proxy :D
  5. wsurritte
    31 Oct 2005
    The only problem I had with IP Cop is how much ram and cpu it uses. My 233 p3 with 64mb ram just couldn't do it. Brazilfw only needs 12mb and has Squid and Tinyproxy.
  6. lcdguy
    lcdguy Minimodder
    25 May 2004
    i don't think that will be an issue in my case since it's running on a 1.6GHZ Centrion with around 512MB of ram :D
  7. Glider
    Glider /dev/null
    2 Aug 2005
    Disable the proxy features in IPCop. Squid needs a lot of RAM to work decently. I allways ran IPCop from a 486 or a P120 with 32MB RAM, without problems.
    IPCop Cheesecake! ;)
  8. RTT
    RTT #parp
    12 Mar 2001
    I think i used to run IPCop on a K6/2 400 with 64MB of RAM with squid turned off :)
  9. lcdguy
    lcdguy Minimodder
    25 May 2004
    i think i have settled on ipcop. I am going to run it on the following.
    Celeron 2.0 GHZ
    768MB DDR
    40GB HD
    Anyone know when 1.5 comes out ?
  10. pano
    pano What's a Dremel?
    29 Jul 2007
    That's quite a monster to run just a firewall :D you will be at ease;)
  11. lcdguy
    lcdguy Minimodder
    25 May 2004
    this is true, but it was free so i'm not complaining :D
  12. pano
    29 Jul 2007
    True, it's always better when it's free :D
  13. lcdguy
    lcdguy Minimodder
    25 May 2004
    yup. fortunately i seem to have found a decent ISP in my area $30/month for 5 meg dsl, no cap :D
  14. K.I.T.T.
    K.I.T.T. Hasselhoff™ Inside
    1 Jan 2005
    IPCop > all in my opinion.
    I've got IPCop running on a P3 800Mhz and 512MB Ram with squid on, IDS on, SSH on, Addon server, Net-raffic addon, ip-table addon, nmap addon, enhanced filtering addon, WakeOnLan addon, GUIListenPorts addon, Uptime-Record addon and finally BlockOutTraffic addon.
    it all runs quite nicely, thats also running a Red, Orange, Green network.
