Networks Smoothwall Web Server??
Discussion in 'Hardware' started by ChriX, 12 Feb 2002.
  1. ChriX
    ChriX ^
    30 Aug 2001
    I saw on the information page of my smoothwall it says "Web Server: RUNNING" is this a web server that I can put files on and people can access them via a dyndns url?
  2. xrs444
    xrs444 What's a Dremel?
    27 Jan 2002
    The short answer is no.
    THe web server module is the one wich doles out web access to your network IIRC. If you wish to run a web server you need to either add another machine to the DMZ (orange) network (Running Linux apache is usually best) and use that as your server, or you can run a web server on a machine in your green network, forwarding the ports to it, although this does leave holes in your firewall.
    My advice is grab a cheap old machine, hook it up to the DMZ (that's what it's there for!) and run an apache server on it.
    Full instructions are all avalible at www.smoothwall.org
    HTH
