Small Form Factor SN41G2 Overtemp solid
Discussion in 'Hardware' started by TheAnimus, 22 Jan 2005.
  1. TheAnimus
    TheAnimus Banned
    25 Dec 2003
    I moved by SN41G2 shuttle back to my house, re-filed the water cooling system, and now i have a strange error.
    As soon as the system is powered.
    The CPU over temp LED lights up, but stays constant, if its over temp, its ment to blink
    This is why i can't figure out what the problem is, its surely not over temp, the systems on for about 1.5 seconds the waterblock is so damn cool.
    any ideas i had a looksie on the shuttle europe site, nothing.
    i've removed the HDD that was connected, so its just the bare board, whacked the water system onto my bench rail (so its not on the PSU to make sure its nice n cool).
    driving me nuts! :wallbash:
  2. JonDixon
    JonDixon Decking is the new modding
    12 Mar 2002
    Sorry if this sounds a bit cheeky, but in moving the PC back to your house any chance the movement, made the waterblock not sit correctly against the CPU?
    Have you re-seated the waterblock to ensure its properly fitted against the CPU?
    Have you tried refitting the ICE heatpipe and seeing if it works with that fitted.
    This will at least narrow down the possibilities
  3. TheAnimus
    TheAnimus Banned
    25 Dec 2003
    Yes re-seated, its fine.
    I'm low on thermal paste thou, so i don't want to use the last of it testing with the ICE pipe again.
    I've put some fans on its fan 1 & 2 line incase it was because of a lack of fan.
    The thing that gets me is the LED overtemp is SOLID. not flashing like it should if it was that!
    i think i'm gonna try another CPU.
  4. Kipman725
    Kipman725 When did I get a custom title!?!
    1 Nov 2004
    I had solid overtemp light in an sn45g and it was bad ram
