Small Form Factor SN45G HDD LED problems - this is a tough one I think.....
Discussion in 'Hardware' started by Halmod, 24 Mar 2004.
  1. Halmod
    Halmod What's a Dremel?
    24 Mar 2004
    Hi All, I have recently purchased an SN45G but I made a LARGE error when I spec'd my system - I presumed that since the last XPC I built had SATA, they all have it and picked up 2 SATA hdds to run in a raid0.........when I came to build.......no SATA connectors :wallbash:
    So I order a PCI SATA card for the 1 PCI slot on the mobo (I had other plans for the slot but thats life... :sigh: ). So I build it and it worx (fast :D no SATA corruption :D :D and nearly silent :D :D :D ) So problem fixed I thaught............then I glanced at the front of the case......
    No hdd activity light :waah: so no trigger for all the cool lighting mods I want to make :waah: :waah: :waah:
    I checked for a connector on the SATA card (adaptec 1210SA) - none, I tried combinations of boot order in the bios - no go, I even looked on silicon Image controller website for a line on the controller I could hack into - can be done with a latch on the read and write strobe lines but requires a mod to the driver code to reset the latch (beyond my capabilities... :lol: )
    Any ideas / circuits / mobo or pci card mods (anything??) would be GREATLY appreciated
    Thanks in advance
  2. felix the cat
    felix the cat Spaceman Spiff
    11 Jan 2002
    iirc my sata pci card has some pins for adding an led, as i had exactly the same issue with my card...so i guess it depends on the card itself...
  3. Halmod
    24 Mar 2004
    Thanks for the reply flix,
    What card do you use (I guess it is in your hardware list but i don't recognise some of the items)?
    I guess I could send the card back but I like its features...... especialy the ability to low level format the hdds
    Do you know what SATA controller your card uses?
  4. Halmod
    24 Mar 2004
    Update:
    Yesterday evening I looked over my rig with a 'scope to find a signal that relates to hdd activity that I can use or convert to drive an activity led.
    I found a pin on the jumpers connector on my hdd (Maxtor +9 SATA) just to the right of the standard 6 master / slave / csl jumper pins that seems to remain high (+3.3v) when the drive is idle and strobe high / lo during activity.
    Does anyone have any advice on running this output through a standard TTL inverter and using it to drive an led (and perhaps a buffer / line driver for cold cathode).
    I am keen to try this mod but I don't want to kill my drive. Does anyone have any tips??
    Thanks.
